Front end vibrating sometimes
I have been noticing a vibration while traveling between 20 and 40 mph.
I replaced the drivers side wheel hub assembly 6 months ago,
I replaced the passenger side wheel hub assembly 3 weeks ago.
Original tires, I should rotate them.
I hear a faint scraping sound when I drive with the windows down, the sound does not get louder when I apply the brakes.
I don't know what to check first.
Any ideas?
Any ideas?
Any ideas?
Any ideas?
Did you check vacuum lines, might double check all the caliper bolts for tightness while your checking over things.
I did check various bolts while I replaced the passenger side wheel hub assembly, not sure if I checked them all.
Thanks for the reply. I will check into it as soon as I have time.
While I was under there I checked the brakes, noting is loose.
Drove to work and still have the scarping noise, so I called Ford.
It goes in Monday.
The transmission hard shift at 25mph is because the transmission thinks i am slowing down and when i hit the gas it revs up and jerks into gear.
No charge for no service, just a test drive.
