Wearing out new tires too quick need HELP!!
First off I'm new and so far love the site. Anyway I have an 04 F150 lariat 4"suspention lift 3" body. I have 35x12.5R18 Nittio Mud Grapplers. I have had all ball joints, CV shafts, and tie rods replaced, I have gotten my truck aligned 2 times in the past 4 months and my new tires (less then 2500 mi) are still showing significant wear on the inside of the tires! And yes I have rotated them! Please help guys I can't afford new tires again!
FarmBoy
FarmBoy
My aunt bought a Toyota a couple years ago that was having the same problem. She got it aligned replaced some things got the tires rotated ETC... Turned out her shop was aligning her truck wrong and that was what had been causing the excessive wear. Also has your truck been in any wrecks or anything?
http://www.google.com/imgres?imgurl&...g&ved=0CAEQsCU
For your tires 40 should be plenty. They are LT LR E tires with a max 65 psi. Max load is 3400lbs at 65, so 40 should definitely be enough for your vehicle. Maybe 45 if fully loaded or towing.
you need an alignment rack capable of ifs front suspension (which is just about all these days).
ask for a print out of the specs before and after (toe, camber, caster). any reputable shop should be able to provide this.
wear on the inside is camber. are the edges of the tread blocks on the outside "rounding off" or do they seem sharp still?
