Just replaced Phasers, Need a little help.
Old Sep 17, 2013 | 08:35 PM
mtmatt's Avatar
I have a 2004 f-150 5.4l 75,000 miles
The phasers used to be very noisy then the truck suddenly stopped running.
After tearing it down I found one of the rockers had jumped off of the cam on the driver side and locked it up. I know there is a risk of debris in the engine but I opted to try to repair it.
both tensioner gaskets were torn in the usual place, I believe that this is the ultimate cause due to low oil pressure that led to poor timing that led to the rocker popping off.
I have replaced the cam shaft, both tensioners both phasers, the valve spring and keeper that were damaged and the timing chain rails. The cam channels were undamaged.
The problem I am having is:
After everything was timed up I tried to turn the motor over with a wrench on the crankshaft and it jumped time. This worried me and now i am hesitant to try and start it for fear of causing damage. I had the spark plugs out by the way.
Why would it jump time like that? Thanks in advance for any advice.
Old Sep 17, 2013 | 08:59 PM
effects4's Avatar
Silly question but did you remove the locking clips on the new tensioners?
There was a little bit of slack in the timing chains after I replaced my tensioners and phasers as the tension is built up via oil pressure. I turned by hand a few times and it was ok.
Old Sep 17, 2013 | 10:45 PM
Use light pressure with a pry bar behind the chain to help the tensioner to pull out to full length.
Turn it over a few times by hand and verify
Old Sep 19, 2013 | 04:33 PM
mtmatt's Avatar
Making sure the clips were out was the first thing I checked. Surprisingly I hadn't forgotten to pull them lol.
I will give the pry bar a try. thanks!
Are these motors interference?
