Rim help..
Rim help..
I'm looking at getting a set of 20s with 33s for my 06 with a 2" level. I'm looking at either 20x9 with +18mm offset and a 5.74 backspace or 20x9 with 0mm offset and 4.5 backspace. I'm looking at doing the 0 offset ones but how far will they stick past the fender? I would like them to stick like an inch or two but no more! I talked to the wheel shop selling the rims and the guy said the 0 offset will stick out an inch is that true? I know the +18mm set will be like stock and not stick out at all.
The 20x9 rim with "0" offset will be a 5" backspacing and will stick out a little close to two inches further than the stock rims and tires. The +18s will still stick out about an inch further from stock. I can get you a pic or two of my 20x9s with 0 offset and 295/60r20s tonight if you want...
Here you go... Tires are 295/60r20 Nitto Trails with 20x9 Fuel Trophy's and a backspacing of 5" (+1mm/0mm offset). All with a 2" level. Sorry about the grainy dirty pics, best I could do for tonight
Personally, I would go no less than a 5" backspacing. 4.5" will stick out way too much on a truck that's not lifted and cause rubbing depending on the tire. The +18mm would have been ideal in my case, but the rims were only offered in +1mm and -12mm. Although I do think it turned out pretty good, I still need to order some EGR OEM flares, as they look to give about an extra inch of coverage.
Hey thanks, I sort of took a shot in the dark going with that rim and tire combo as I couldn't find anybody running anything close on a leveled truck. As far as stick out, looking down from the top of the flare, the tire sticks out about 1.5" past the flare. Really depends on the tire though, AT vs MT ect.. Those 20x9's you're talking about with 0mm offset will be a 5" backspacing just like mine. Only way to get a 0mm offset with a 4.5" backspacing is with a 8" wide rim.
Heres a handy chart showing how backspacing and offset correlate...
Maybe just a little bit more than mine if you go with a 33x12.5x20. My 295/60's measure 34.25x~12. Also depends on manufacturer and if its an AT or MT. So far I don't think I've ever had a better truck tire than the trails that's on road friendly. Great traction in every condition, extremely quiet and seem to be wearing well so far. Only complaint is their so fricken heavy.
Just double checked with the rim shop and they said the 20x9 0 mm offset is a 4.5 backspace. I will be doing MT tires so they will add a little too.. How much will the 0mm 4.5 stick out? I don't want them to stick out too far and look stupid especially since I only have a level and not lifted.
Backspacing and offset go hand in hand, two measurements from different parts of the rim. The offset is the direction and amount the hub surface is from the middle of the rim. A minus number will be closer to the backside of the rim and a positive number will be closer to the front. 0mm will be centered. Backspacing is the distance from the backside of the hub surface to the backside of the rim. So you can't have one number without having another, as the chart shows. Stick with the 0mm or a positive number and you should be good to go as far as leveled trucks go. And try to stay away from 10" wide rims.
