PDA
View Full Version : 2004 - 2008 F-150
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219
  1. FX2 w/ 2.5" leveling problem, need advice
  2. open your hood and help me out with this!!!!
  3. 2005 4X4 torque specs for front suspension
  4. 06-08 rear bumper question
  5. Oil Pickup Screen - Clean or Get New
  6. Front Dome Lights Don't Work
  7. Custom Frame Spare Battery Mount
  8. New tire size, what should I do next?
  9. Fuel relay/fuse 2005 f150 5.4
  10. Door open chime
  11. Much needed update
  12. AutoAnything's February Specials!
  13. Wanting to swap out stock diff for Eaton Truetrac
  14. [Guide] Convert your Edge Evolution into a Gryphon+Custom Tunes
  15. [GUIDE] LED Cube Hood Lights Install
  16. help diagnose, keeps dieing, starved, black smoke, rich sensors.
  17. 04 with 2.5" level kit and 295 70 17s, do you have this set-up?
  18. 2004 FX4 Build from Ga
  19. Moving truck to Alaska, Tow or trailer?
  20. Moonroof with "overhead mini-console"
  21. Spark Plug change
  22. Dealer Shenanigans
  23. Anzo u bar headlight installation
  24. 2004 5.4 oil pressure gauge pegged out
  25. Custom Rear Bumper
  26. Another console / jump seat swap
  27. Custom Winch Bumper
  28. Random Vibration front wheels hot
  29. Custom Winch Mount
  30. Thinking of upgrading, What year?
  31. power steering issue
  32. 2004 scab fx4 Radio won't turn off with key out
  33. 04 F150 Tire Size Help
  34. Lifter And Rocker Replacement
  35. need help solving code P0512
  36. Fitment Question: 295/60R20
  37. 5 lug conversion
  38. Another Tire question for you guys
  39. New truck is jumpy over bumps at high speed
  40. Will 295's rub on stock 20s with 2.5 level??
  41. 'Clunking' Noise From Front-Left When Turning Right Only
  42. 08 Mark LT very bumpy ride!
  43. 2007 Screw 4x4 Needs New Shoes
  44. New wheels
  45. Question on 4x4
  46. What is this goop?
  47. Insurance Job Woes
  48. 2004 supercab seat fabric sq
  49. Tire Size
  50. Exhaust help
  51. Radio replacement
  52. Component system in the rear? Alpine Promo on Crutchfield
  53. Interior dome lights, radio, inst cluster not coming on
  54. Informal Good Bye
  55. Lifters And Rockers?
  56. 2004 5.4 as second truck?
  57. phasers on 5.4l 24v 2005
  58. 4x4 Switch Battery Light On
  59. 2005 Fail to Start - Injector Warranty ?
  60. Custom led headlight retrofit
  61. Fix or sell... Look for opinions
  62. ABS Light
  63. Flex fuel in an 04?
  64. Power Mirrors for XL owners anyone?
  65. 5.4 swap questions
  66. 04 FX4 will new 2015 seats fit as replacement
  67. crank/no start issue narrowed down to fuel pump
  68. Horn beeps twice on keyfob open
  69. 07 F150 has no power gets terrible mpg
  70. 2005 F150 CC drivers door latch cable
  71. 2007 XLT SCREW Adding OEM Fog Lights
  72. Making a little progress ... Saleen hood, lowered 4wd, grill, etc...
  73. 2004 F150 FX4 sun roof question
  74. What's up guys! I have some questions about my leveling kit on my f150
  75. Stutters under load
  76. Shudder...Misfire???
  77. need help solving code
  78. Instrument Cluster Draining Battery
  79. Oil usage
  80. phaser delete kits
  81. 2004 f150 longbed
  82. replace transmission at 140K
  83. Rigid Question
  84. Coolant crossover tube or intake leak on 2004?
  85. 4.2L performance help
  86. Headlight change to LED?
  87. 2005 F-150 Lariat - Blower motor not working - EATC
  88. Thank you Optima!!!
  89. Part # help!
  90. Fuel Pump Replacement and Problems
  91. Steering stiff to turns
  92. Tips on 4.6 #8 plug removal?
  93. Accessories
  94. Need some advice
  95. Mod suggestions 06 xlt HD
  96. S331 Wheels
  97. Need part # to replace a part
  98. Fuel filter
  99. Towing Mods for '06 STX 4.6L
  100. Drivers window works but others dont
  101. 04 f150 fx4 super crew rear passenger window.
  102. Done it all Phasers,timing chains,vcts, lifters, etc.. and still ticking and stalling
  103. Which axle shaft and part number?
  104. help me put a value on my truck
  105. obd power issues
  106. rear seat backs uncomfortable for long ride
  107. coil to plug fitment???
  108. 2006 F-150 KR Battery dies
  109. Tires Rubbing ~ NEED HELP
  110. 2007 5.4 false overheating
  111. New blower resistor switch failed?
  112. Camshaft Positioning Sensor (How To) needed
  113. throttle/brake issue
  114. Extremely cold start whine sound
  115. leaking oil problen
  116. MSD coils, $239 for set of 8
  117. Upper control arms and steering rack
  118. Plowing
  119. Buying new tires
  120. Driving home in snow!!
  121. Throttle Body Assembly Help
  122. Sp515 plugs will break again?
  123. Mechanic fixed Camshaft Pos. Sensor now truck rough idles and turns off
  124. 4x4 actuators (iwe)
  125. want/need to buy
  126. 04 fx4 super crew. Needs help!
  127. What Should I do with my truck?
  128. 2008 f150 wiring nightmare
  129. Question on side mirror wiring
  130. replacing parts to end ticking
  131. Spark plug change from hell. Pic inside
  132. Tapping noise
  133. Upgrade headlight bulbs
  134. Code Alarm Issue after replacing truck battery
  135. Suddenly lost directions!
  136. Random guy had me pull over tonight because...
  137. $10 Off & 4 Free Gifts from TonnoPro!
  138. Weird noise after it rains
  139. 2005 f-150
  140. 5.4l rear end onto a 4.2l
  141. Snow pics of the Lariat.
  142. 04 F150 no forward gears
  143. What gauges are you using in your scangauge II?
  144. 06 Explorer Overdrive question
  145. Installed: Audiovox Headrest DVD
  146. Ever used the Dorman oil drain plug?
  147. 5.4 3v Running like crap, stalling, Bucking
  148. brake and cruise problem
  149. LED tailgate bar fit issue
  150. Throttle body gasket
  151. Anyone Familiar with Detroit Axel?
  152. 2004 f-150 ticking and stalling at idle
  153. Westin HDX Grille Guard '05 STX
  154. 10% Off All BEDRUG Products & $30 Visa Gift Card
  155. AutoAnything Extends The Specials!!
  156. Is an Optima Battery worth the extra $$$
  157. car starter install bypass thoughts
  158. Truck wont crank, P0022
  159. Steering wheel vibration when going over bumps
  160. Front diff carrier
  161. Have a 4.6 now? Need a motor? 5.3 liter?
  162. Front Lower Ball Joint Recommedations
  163. please help codes p0171 and p0174 and airbag code b2292
  164. Head swap
  165. 06 F150 King Ranch
  166. Powder Coatin near Tallahassee Fl
  167. Feel like i'm beating a dead horse here, sorry.
  168. New build... saleen hood, 09 up Harley bumper, etc...headlight ?
  169. 06 5.4 Cranks but No Start Fuel Delivery Issue
  170. Hard Starting F 150 w/ 5.4
  171. Need help please.
  172. Where to buy harley style heads at?
  173. E brake not holding in reverse
  174. 2007 f150, 4.6 coolant leak between aluminum crossover and plastic intake
  175. Ford 5.4L 3v Engine Timing Walkthrough
  176. 4WH not working, 4WL works fine
  177. After 3 years, i'm back in a F150...
  178. Strange Sound Transmission?
  179. Move Front License Plate on 05
  180. 06 cluster lights
  181. 07 locks up in reverse
  182. PS fluid level?
  183. Airbag Light help
  184. Cabin Lights on and off issues -- ideas?
  185. WTH is that front end noise?!
  186. Projects to be completed on my truck.
  187. 2006 F150 King Ranch 4x4 CD Player
  188. Got Rearended
  189. fuel pressure sensor
  190. help
  191. New rotors but wheel bearings are failing? HELP!
  192. Car cover suggestions?
  193. F250 with 5.4?
  194. AutoAnything’s Black Friday/Cyber Monday Sales!
  195. Transmission lines rubbing on PS lines
  196. missing at low rpm
  197. Behind seat storage tray Regular cab
  198. 06 F150 4x4 grinding when actuated while moving
  199. Sunroof won't sit Flush
  200. Lost all my keys.. still at a loss with the replacement..
  201. Battery light has been on for MONTHS, no issues. Any ideas?
  202. Mikeys 06 XLT build
  203. VCT Solenoid grommet removal?
  204. Where to find 3rd brake light socket?
  205. 4x4 not engaging light on half shaft turnig
  206. New Headlights
  207. Scangauge II worth it?
  208. Truetrac Diff
  209. I Need Window Tint Opinions!
  210. help with PO174 04 F150 5.4
  211. Wanting an Eaton Truetrac- Questions
  212. Best way to seal new 3rd brake light, that's remivable?
  213. Gas gauge issue?
  214. interior swap/replacement
  215. Front end chirping
  216. Squeaky passenger front end
  217. Blown tranny!
  218. No start. Running out of ideas
  219. Trouble starting
  220. Gatorback belt size
  221. Axle Bearing or Rear Wheel Bearing?
  222. eBay retrofit headlights
  223. Opinions on these grilles?
  224. Low Mileage 2005
  225. Clutch fan, normal or not?
  226. Carling Rockers Switches Mount
  227. front rumble/vibration...
  228. Fibreglass Tonneau - Very Hard To Open
  229. Broken Leaf Spring 04' F150 Fx4 "Question"
  230. High Beams won't work in Auto Position.
  231. Mounting rigid industries 54" light bar
  232. Heater Issues
  233. Medium pitched whine from under truck
  234. 04 S-CREW, rust questions.
  235. OTC Tool for 5.4 3v 4.6 3v broken spark plugs
  236. Fuel pump brands_Delphi, Precision (O'Reilly) or ?
  237. bouncy ride issue. please help!
  238. Steering Intermittently Tough
  239. Using 20% more fuel.
  240. Trans fluid change!
  241. replacing keyless entry keypad
  242. 4 Wheel Drive Issues
  243. vibration in 4wd
  244. Tire load rating: 10ply or 4 ply
  245. Chipmunk spent the night in engine bay, concerns?
  246. 100k maintenance (anything I'm missing?)
  247. 4.6 Tune Up Parts: Plug Wire Mystery
  248. 08 Lariat strange issue
  249. Plug change success
  250. f150 2006 truck wont start
