Throttle body gasket
Old Dec 17, 2014 | 08:23 PM
05fordf150's Avatar
I tried a search and couldnt find an answer. Im going to clean the throttle body and maf sensor on my 05 f150 5.4 3v soon. Is there a gasket for inbetween the throttle body and intake manifold? Also is it ok to move the throttle plate with the TB removed from engine? Thanks.
Old Dec 17, 2014 | 08:37 PM
The electronic throttle body should not be moved, if you do, be very slow and careful.
Yes, there is a gasket between the throttle body and spacer.
Old Dec 17, 2014 | 11:34 PM
05fordf150's Avatar
Spacer? I havent put a throttle body spacer on my truck
Old Dec 18, 2014 | 12:07 AM
The stock spacer.
Old Dec 19, 2014 | 03:20 AM
Try not to move the blade
It sits on a oring gasket....reusable until it's flatten or starts to peel chunks out
