No start. Running out of ideas
Old Nov 14, 2014 | 08:16 AM
Justin94's Avatar
I have a 2004 new body style f150 5.4 that I can't get started.
I had my dad drive it to my house and he told me it started weak and then it sat over the weekend. First thing mon morning I get in and have radio/headlights ect but nothing from the solonoid or starter. The only noise I get is from the relays clicking. I charged the battery and changed the terminals with no difference. Then I was underneath the truck getting frustrated with my volt meter on the starter and started knocking on it with a wrench while my dad tried turning it over and it started after a few try's. At that point I pulled the starter and had advance check it (it's a remanufacterd starter I bought a year ago) and it worked fine for them... I tried bench testing it myself on a couple battery's and it spins but doesn't engage. But I put it back on and bought a new battery with the larger ca I could find climb in the truck turn the key and nothing. Tried about 4 more times and it worked, just til urged over weak. Drove it for a while shut it off and same thing had to fight for a few try's to get it going. Since the. I can't get it to do anything. I've also tried switching the relays between the high beam and starter solonoid relay and I've checked for voltage pass the fusable link. When I was checking voltage at the starter I get about 6 volts coming from the ignition and I have yet to see voltage at the main wire from the battery. I'm running out of ideas. Any thoughts?
Old Nov 14, 2014 | 08:30 AM
Justin94's Avatar
I've also tried turning it over in neutral and checked all other fused that could be related. Only fuse I found blown was for the code reader port but I think that's been blown for a lil while
Old Nov 14, 2014 | 10:27 AM
littlejohn33's Avatar
It really sounds like a bad starter. They can test good and still be bad.
Old Nov 14, 2014 | 10:34 AM
Justin94's Avatar
https://www.f150online.com/forums/20...ank-start.html Found this and I want to give it a try when I get home but yeah I'm about to just pay for a new good starter and cross my fingers. Had problems with my starter last year and replaced it with a cheap remanufacterd one so mybe it's falled again
