Steering stiff to turns
Old Jan 16, 2015 | 11:34 PM
YOMAN's Avatar
My truck fx4 5.4, crew. At 104k
It's pretty cold outside under 20's
I'm not sure if it's causes by cold.
The steering wheel is a bit stiff to turns left/right but it will return to center slow
I feel like there's very low psi in tire up front.
I checked the fluid it's full.
How to check rack and pinion??
I have see there's common report about lower shaft.
I could see it's very rust at joints area and I used white grease spray it but didn't help that !UCH.
Your advice will be helpful.
Old Jan 17, 2015 | 01:30 AM
61 falcon's Avatar
the lower shaft u joints binding is common. remove the shaft and check the joints. 2 bolts and its off. i replaced a lot of them over the years when i worked at ford dealer.
Old Jan 17, 2015 | 07:57 AM
MGDfan's Avatar
OP.
To add the above, here's a How-To:
https://www.f150online.com/forums/ar...t-04-08-a.html
MGD
Old Jan 17, 2015 | 10:46 AM
YOMAN's Avatar
Thats what i figured after searched
Figured ill just go ahead and buy new part since its over 100k and is my daily driver
What brand is good to buy?
Kind of want avoiding stealership prt dept due to cost
Thank you
Old Jan 17, 2015 | 11:56 AM
Call Tasca or PM the Tasca rep with your VIN to get wholesale pricing on OEM parts.
Old Jan 20, 2015 | 04:24 PM
Ford Fanatic's Avatar
My steering has been getting tight the last few days. After doing some research on a couple forums I went home and sprayed the steering shaft u-joints with some WD-40. It confirmed that the shaft needed replaced. I ordered this, this morning. Thanks for the help.... http://www.ebay.com/itm/like/181210052512?item=181210052512&lgeo=1&vectorid=229466&rmvSB=true
Old Jan 20, 2015 | 04:35 PM
ak_cowboy's Avatar
There was also a TSB out for vehicles in cold-climates. The power steering hoses and become compromised and cause difficulty turning.
Old Jan 20, 2015 | 04:42 PM
Funny you say that, my first thought was the pressure hose was closing in on itself because of the cold. No leaks, fluid level was good, pump wasn't whining, belt not slipping....that's all I could come up with.
Old Jan 20, 2015 | 07:22 PM
ak_cowboy's Avatar
http://tsb.govwebs.com/5-vin-v854l-p...006-16262.html
TSB 7-21-3
OCTOBER 2007 Power Steering - Cold Weather High Pressure Line Leakage
Old Jan 29, 2015 | 09:31 PM
casey10's Avatar
Had this problem with my 2005 F150 XLT. ordered the part at carid.com, $148 US +35.25 shipping ($219 canadian) Dealer wanted $500 + tax. Delivered to my door by UPS with additionaal duty tax of $34 canadian. Steering now is great !! I live in NB, canada
Old Jan 30, 2015 | 07:16 AM
USAFJETMECHANIC's Avatar
Had the same problem with my '09. I did a full, (as much as physically possible anyways) fluid swap and it fixed my problem. Probably wouldn't hurt to do anyways if you haven't already.
Old Jan 30, 2015 | 09:22 PM
Changed the shaft earlier this week, steering turns is smooth as butter now.
Old Feb 1, 2015 | 08:34 AM
x2. I exchanged my fluid out when I did a brake fluid swap & bleed, both felt a little better afterwards, and clean fluid in the reservoir looks healthier to the eye also. Peace at mind.
