Mod suggestions 06 xlt HD
Hey guys need some advice I'm sure there's threads but I'm not the best at navigating. I want to replace my stock wheels and do either 2.5in level or 4 in maybe. Open to suggestions, the only problem is I have the 7-lug had payload package. I see tirerack.com has the ultras
Check mine out, I have the same one, but in green.
Fuel and MHT make 7 lug wheels also, and the ford 2012+ ones are pretty nice also.
http://www.fordfullsize.com/forum/f1...ild-thread-96/
If you're going to replace just shocks, I would do Bilstein 5100s all around. If you want to do coilovers, Fox makes a complete replacement for the front, but it's a lot more expensive.
The rear suspension has heavier leaf springs, but the same crappy shocks.
Shocks are never a waste on these trucks. The OEM shocks/struts aren't real good after too long. Rancho and Bilstein make great replacement shocks/struts.
Check with rough country. A lot of times lifts require certain offsets.
4" would be nice, but a lot of guys jump to 6" since it's so easy. Call Rough Country and make sure they know you have the 8200lb package. fwiw, the 17" steel rims are only 7.5" wide, and it's not recommended to run 12.5" tires on them.
You'd go with the blisteins over a 4' rough country lift? I like going up the mountain where I live to swim and chill , it's kind of rough so I think the 4 inch might be better. Any input is great. The price difference is like $500 which isn't bad.
The question is "offset" and "paint" afterwards?
Been checking out your thread thanks man.
