View Full Version : 2004 - 2008 F-150
- Truck died completely.....
- Rubbing at full lock-need help
- 06 F150 idles rough/stalls hardly drives!! help please!
- Ranch Hand Headache Rack
- Limp home mode?
- Detonation or IWE?
- people with westin grill guards please help
- Attention Lowflyer
- Need to give it gas to move in gear
- Truck at shop, lift finally going on!!!
- 2005 F-150 Questions
- your favorite SISO catback exhaust system
- What Is The Difference Between These Two Models? Please Help!
- f150 troubles!!! please help!!!
- Successful plug change
- Fuel system or pcm?
- Fuel Pump Driver Module
- Painting rails, cowl, flares, handles, and badges.
- What size Magnefine install
- Rusting Cab corners
- Ford expands F150 recall 2004-2008
- Quick question about MOOG ball joints.
- Havent Been On in a While... Update with pics on truck
- PTM questions and opinions on color
- F-150 airbag recall expanded
- New to the site and have a few ?s
- Hail damage - Opinions on best repair method
- Need Direction... P0345
- extended mirrors for 2006 F150
- Rear Rotors 230 degrees, Front Rotors 130... hmmm...
- 2011 Ford F-150 Ecoboost Torture Test
- OK so NOW I got a good one....2006 screw
- What is the purpose of having a sensor on the fan clutch?
- What could be getting wet and causing a miss?
- Leather treatments?
- Need a new tailgate
- vibration
- Difference between Pennzoil Platinum and Ultra?
- Will these trucks go 200k miles?
- Kleen Wheels
- What is this?
- 2007 Front Hitch Help
- Any interest - Rize 12" Kit
- 2005 FX4 Trans slipping bad!
- ~ Leather Kit opinions....need help.
- 2004 F150 FX4 Travel Trailer Towing?
- Some questions
- just to hit 70k with my truck and....
- Hesitation, rough idle after plug change
- 07 powrer steering pump problems
- Pocketflares--double sided tape?
- Best backup Camera
- Feels like I'm pressing on gas and brake at same time
- Steering Wheel Vibrations at Highway Speeds
- Fuel Pump Driver Moudle
- My 04 FX4
- 2008 F150 battery light
- Tell me what yal think
- F150 Horns
- 2004 F-150 STX 2in Leveling Kit WILL 35 Inch Tires with 20 inch wheels Fit?
- 2008 trade in value
- 275/65/20 Michilin on factory setup work?
- Just got back from the drag strip....and had a decent day
- Spark Plug Change
- New Pics of my truck
- Smoked fog lights
- drilled and slotted ebay rotors
- Hey new to forum, Tell me wat u think of my truck.
- MY 2008 F150 progress
- Traded in My 07 Super Crew
- Sucsessful plug change
- Low fuel reserve
- Ford's Fix For Air Bag Recall?
- Ipod/Phone AUX PIE FRD04-AUX
- Listen to this possible trade
- Some high mile 04+s
- again spark plugs
- Fuel Pump Drive Module Part number
- what to look for in a knock noise. suspension related
- No Power
- Speaker Grille Part Number??
- Should i be complaining?
- Spare tire cable lowering trouble!
- Nitto Crosstek
- DIY transmission fluid exchange question
- 4.6 Performance suggestions/tips
- fuel fill problem
- Need help finding a radiator hose insert.
- 35x12.50x17 plz help
- Removed chrome piece, plastic wont return to black??
- What would you sell this for?
- Who has the service manual
- Something always goes wrong after the dealership
- Upgrading mirrors
- 04 heritage/cruise ?
- Best site for LED bulbs ?
- 94k Miles and HORRIBLE MPG's.
- Ford dealship service dept issue
- cheap fx4 cluster find on ebay to anyone interested!
- 4 pin to 7 pin trailer wiring
- keyfob question(s)
- fpdm question
- 08 Shifter adjustment
- which weight distribution hitch?
- Loud Vibration in cab
- Stalling and no power bad cat?
- Whats the value of my truck?
- Anyone have sqeeks in the cab.
- New Lift. Tire size?
- yet another my truck will not start thread help! please
- finally got my truck clean :)
- what PA speakers are you guys running?
- plug situation need idea
- 05 f150 5.4 3v misfire P0351 white smoke rough idle
- Chrome Handle to PTM???
- 04 SCREW: What happened to $99? And I GOT MY 22's!!!
- would you buy this truck?
- Extended waranty
- Where to buy power slot rotors?
- Took some pics of the truck today
- Spark plugs!!!
- Side mirror plug 08 to 09, plug difference?
- 06 round fog Setup Q?
- Painted tow Mirror Caps
- Tow Mirror Led MOD
- tire and gear questions
- Need a service manual
- Bumpers
- Opinon: Anyone Order From These Guys??
- New to the site. Heres my truck
- Whats next?
- Riddle me this.....
- 2004 5.4 whistle????????
- Need new factory seat cover
- Show me your Wheels Sotck or aftermarket
- 2008 mirror top on 2009 & Reflector question?
- My wheel and tire transformation
- Friction modifier
- OFFICIALLY an F150 owner and member...
- fx4 skid plates
- Newb: VCT Solenoid Removal
- My 04 hauling pellets!
- !?! winch help !?!
- auto dimming/compass rear view mirror wires?
- 4.56s-price too high, or just me?
- High Idle Issue
- Goodbye Ford :(
- Power steering pump
- Installed Troyer E Fans
- function of fuel pump driver module (fpdm)?
- finally some pics of my ride
- Truck died then started but wont start now
- need help identifying part!!
- Truck at Lakefront
- Speedo Help
- lift, rims, and tire fitment?
- Shudder in cruise control
- Adding a power steering cooler
- Ball Joints
- Anybody running the 2009 & up 18" FX4 rims on your '04 - '08 truck?
- chrome or black?
- CV Joint?
- Will new wheels with backspacing...?
- Stephens F150 08 FX2 Photoshoot
- Anyone ever negotiate your byback ?
- light fuel smell,boging
- Matt's '07 Retrofit Build Thread
- towing mirrors?
- Dash reflection on windshield, how to eliminate it?
- Help: Which wheel looks best?
- anyone else seen allot of junk in their trans pan when changing the filter?
- Removing Stock Fan
- Which X universal pipes is right?
- 2011 tailgate on an 04?
- Dome Light isn't coming on?
- need a measurement to see if a CrewCab will fit in garage
- Dipstick problem...
- 35's with new gears. What's your MPG?
- Alternator messing with VCT?
- anyone got a winshield strip? i cant decide if i like mine.
- Towing with 5.4
- controller under spare tire.
- federated auto parts axle hub assy.
- Gears or Coilovers?
- Front Emblem
- bad experience at the dealer.. LETS HEAR EM!!
- Could this really help this much?
- Took step bars off!
- Should I get lockers?
- 3/5 drop Camber adjustment?
- New tires... MPG took a dump
- 2006 5.4 lariat plugs, rotors & pads
- My Options...
- Who's got a 2004 5.4 163" WB Heavy Duty??
- Advice on gears please
- Quick Question???
- Tire Question
- Upgrading Shocks on Lifted 2008 F150
- Cheap Easy Mod
- Transmission malfunction came on this morning.
- Does anyone know what this part is?(Pic)
- replacing plugs-new boots needed?
- Pictures!
- 2005 need help
- actual performance gains from K&N CAI and custom 87 oct tune on gryphoon
- DFW Dealerships best deal on plug change
- adding ambient temp sensor to 05 stx with 08 fx4 cluster??
- Need opinions before purchase
- 5.4 1 peace spark plugs?
- Dielectric Grease
- Help wont start
- Pull the motor for headers? 4.6L V8
- Loss of acceleration function
- Replacing Shocks
- brake pedal feel. all the way to the floor?
- f-150 rough idle problem, help please
- Replacing Torque converter
- 2006 5.4 Plug not broken but won't come out
- How to unplug Fuel Pump Driver Module??
- My amature photography at work...
- When to replace rotors?
- Help with rims
- So I got a new paint job, and tires!!
- built in garage door opener
- Dealer screw up or common practice?
- Got a new truck!
- po351
- 2004 F150 Replacing Wheel Bearings
- my 2005 roush with saleen grill :)
- 2008 F150 transforming.....
- Dealer is recommending these services
- Knocking in rear brakes. Need help!!!
- high mileages 5.4 3v
- Spark plug jamb nut broke
- Black knobs near cup holders
- Well let the ole girl go
- Rancho Quick Lift and RS9000xl settings
- 2004 F-150 Plugs - First 2 broken - Porcelain Chipped
- What are the known problems for 04-08's
- Best place to get spare key and Wagner ThermoQuiet Ceramic Brake Pads
- OEM Trans Pan w/ Drain Plug
- bilstein 5100 pricing
- Oh Florida...
- Fuel smell in cab
- About to place an order
- New Campaign: "Got Roush!!!" + some unecesary bitchin!
- IWE & Vacuum Question
- bilstein/spacer question
- Greasing MOOG Joints
- eeddggeee
