Stalling and no power bad cat?
Old Apr 4, 2011 | 09:28 AM
shively's Avatar
Hey guys could a bad plugged cat cause my truck to stall? 06 f150 fx4. Changed plugs and cops last week took it for a ride and still runs like crap and now is stalling out when coming to a stop or slowing down. It threw bank 2 bad cat code before I got the plugs changed. When in gear idling im sitting at about 200 rpms.
Old Apr 4, 2011 | 09:39 AM
shively's Avatar
I also changed the fuel filter... still no good
Have you tried cleaning the maf and throttle body?
Old Apr 4, 2011 | 09:40 AM
khendrix2374's Avatar
Welcome to the club. I wish I could help, but I'm in the same boat.
Old Apr 4, 2011 | 09:43 AM
shively's Avatar
No i havent... The shop owner said he would clean the throttle body when i brought it in to get the cats installed...
Old Apr 4, 2011 | 09:44 AM
And to 88 racing;
Yes. I've done both multiple times.
Plugs changed
Throttle body changed along with new Throttle position sensor
I crawled under it yesterday and looked at the Fuel Pump driver module. It didn't look all that bad and it wasn't cracked. I didn't remove it for fear of damage and not having another close at hand.
Old Apr 4, 2011 | 10:31 AM
shively's Avatar
When you get on it and tack up the rpms while driving does it feel like your hitting a rev limiter?
Old Apr 4, 2011 | 12:00 PM
shively's Avatar
Cleaned MAF still running bad... I'm still thinking the CAT is plugged...Ordered some High Flows should be in this week
Old Apr 4, 2011 | 12:35 PM
If it threw a cat code (P0420/P0430?) it's probably plugged.
Old Apr 4, 2011 | 01:46 PM
No. If your truck has a fouled cat, I'd say somthing else is wrong with it too.
Old Apr 4, 2011 | 02:01 PM
shively's Avatar
I "think" the bad plugs fouled the cats. I dunno but i really dislike this truck right now.
Old Apr 4, 2011 | 02:38 PM
SoonerTruck's Avatar
What brand of plugs did you put in?
Old Apr 4, 2011 | 02:40 PM
shively's Avatar
Motorcraft
Old Apr 4, 2011 | 02:43 PM
shively's Avatar
If I hammer on it it doesn't even reallyaccelerate. Just sounds like I'm hitting the rev limiter. Then it will want to stall when coming to a stop. If i keep on the gas and the rpms up the check engine light will flash and the truck will shake.
Old Apr 4, 2011 | 03:00 PM
Have you checked the injectors? A leaky injector could be flooding a cylinder.
