View Full Version : 2004 - 2008 F-150
- ‘06 5.4 gas to diesel swap questions
- Strange electrical problem with cluster
- Need help - 5.4 not starting.
- Cluster brake light on E-150
- 2004 heater won't work
- Help me find this harness...please
- 06 First take off grind/groan/vibration
- E-vap
- ABS light and ABS activating
- Broken Plug Won’t Come Out, Head Coming Off, Help Needed
- I need a rear end for a 06 F150
- broke ground post on solenoid
- P0622 code
- cranks but will not start
- Runs rough after warmed up
- 04 f150 wont turn off??
- Headlight problem
- Leveling kit and towing question
- gas pedal not accelerating
- Turn signal led lamp in side mirrors - not working
- Freedom Racing Timing Kit part #s?
- Hi I have a 2004 F150 the anti-theft code 13
- Spark plug with broken nut
- Rearend Noise 05 f150
- Starter issue 2005 fx4
- lack of power
- rattle in rear doors
- Is this a failing power steering pump?
- Borken Valve Cover Bolt
- Muffler swap can i put a muffler from a 4.6 on my 5.4?
- moving my actuator switch for 4wheel drive .
- Need help after cam phaser replacement.
- 2006 Texas Edition Questions
- Mini message centre - 2005 ford f150 fx4
- how much does it usually cost to replace upper and lower control arms on a 2005 f150
- Phaser lock outs installed!
- 2006 F150 5.4 surging with acceleration
- Can I replace front rotors on a 2WD using 4WD rotors? Thanks.
- beeping sounds
- Door Check Bolt
- Can you bench test a COP?
- My new 2004 F150 FX4 supercab with 5.4
- Brake and ABS light on
- Electrical issues after adding LED lights
- Dome Light Problems
- Hard Starting Issue
- Front Crash Sensor
- High beam switch output wire location?
- Before and After
- No Blower Motor for Heat - In Alaska, yay.
- coil misfire #5
- What color is This?
- Screw insert coming out with screw on coil pack on 07 f150
- ABS trouble
- 06 no vacuum at either actuater
- 2008 F150 Shaking after Towing
- Do I need to reprogram with this tire upgrade?
- vin numbers
- 2004 FX4 No Power Steering
- 4 wheel drive not working
- 2005 F-150 heat/air not working
- New motor going in, oem phaser or lock out?
- How much should I pay for this f150
- Idle speed vs cam phasers?
- Slipping/Knocking from 40-50 MPH
- Serpentine belt help
- Bad vibration - Engine misfire or timing?
- EGR valve
- No Read on Oil Dipstick When Cold
- Front End Clunk Noise (Solved - Just Sharing)
- 2006 F150 Tailgate Cap
- My truck sound like a leaking baloon..
- Lift Spindles and Fitment
- 2006 Lariat New Front End
- anyone replace your brake booster?
- Which Phasers
- 2008 F-150 Rapid Clicking Noise Upon Startup???
- I need help
- Ford F150
- 04 f150 xlt 5.4 v8 horrible idle and stalling
- 2004 Triton 5.4L 3V Major issues with Idle
- rocker panel rust panels ?
- 2008 lariat
- is there something wrong with my ecu?
- Time to say so long!
- Fitment
- Today I said goodbye
- 08 F 150 5.4 gone nuts
- When being a good Samaritan blows up in your face
- New to me 2008 F-150
- Flareside owners! Want to trade beds?
- BCM replacement for 4 wheel drive issue ?
- will 35" tires fit
- 2004 F150 rear bumper interchange
- p0132 bank 1 sensor 1 issues
- changed out the plugs.....
- Series of events, now truck won't start....ideas?
- F150 4.2 L actuator, how to test?
- Reduce Engine Power
- 2004 F150 shaking/vibration when parked and at stop lights
- Hello everyone
- 04 stx regular cab
- Fuses
- 2008 f150 - P0305 cylinder 5 misfire detected
- Unplugging the computor
- Inner Rocker Panel Replacement
- 06 f150 fx4 5.4l 3v
- Exhaust Replacement Suggestions
- New 4.6 rotten frame
- Engine Block Heater
- 05 F150 5.4 Dumping Fuel Big Time
- 05 FX4 Stuck in low range
- rpm
- should i buy?? needs cam phasers and it stalls when warm
- New shoes!
- Cleaning The Throttle Body
- Brake light
- 04' 5.4 Failure to start WITH A TWIST (fuse 102)
- Finally found the one thing I hate about my F-150.
- 2004 f150 PO325 knock sensor
- won't go in P and keys are stuck in ignition
- Just hit 150k what should I look out for?
- Canadian crooks have good taste at least...
- Which Grease for Moog Uppers?
- Ouo Trac bars
- Keep Getting Misfire on Same Cylinder
- Heater Core help
- 05 F150 ticking/tapping noise
- 2005 F-150 vs Navigator
- Help?
- New Ford Owner - Needing help with Misfire and spark plug change.
- can i put camera in my 2004 f150 xlt
- 2008 Mode/Blend door stuck on vent only
- 2004 F150 Fuel Guage on Empty/Below Empty
- I just ordered ouo trac bars.
- Shudder at 15-20 mph
- Could moisture keep it from starting?
- Just at a loss and besides myself
- 2007 f150 fuel lines
- Tuner help
- center rear slider window removal
- If I overfilled my transmission
- Convert 2wd 2005 f150 to 4x4 - with donor truck
- bolt hole pattern
- Advice on buying high mileage?
- 4.2l supercrew?
- Is this a leak from the heads?
- Coolant Degas Container
- Rough idle
- Electrical Problems
- Tire problems... Needing help.
- Why won't my 2004 F-150 4X4 go over 100 MPH
- Shifter Handle Alternatives?
- 2005 f150 5.4 l 4x2
- What should I be replacing? '08 4.2L V6 @ 45k miles
- Vibration @ 2000 rpm
- Relocated front brake lines with Lift
- Loss of all forward gears, but still has reverse
- 04 f150 fx4 supercab 5.4 3 valve swap with 5.4 2 valve from 04 f250
- No sensor on aftermarket high-pressure PS line?
- Center Cap for 20" Roush Rims
- Upper control arm help
- New style 3pt jump seat.
- 2004 5.4 Multiple Codes Please Help!
- Differential knock when coasting
- Squeaky front end after installing new struts
- Transmission swap
- 2004 F-150 FX4 Heater Core
- Stainless Steel Exhaust Manifold Bolts
- 2008 F150 Awd Problems
- 2008 F-150 Intermittent engine shaking
- Question about possible steering rack damage..
- Esof 2005 f150 not engaging
- Please, please help. I'm completely lost. How does this rack come out!?
- Jump seat removal
- Sounds and feels like abs jitters when taking off
- 2006 Lincoln Mark LT Locks
- Towing Capacity
- Lower ball joint space
- OBD Scanner unable to read from diagnostics port.
- 2008 4.2L crank no start PCM?
- Swap 4r70e transmission with 4r100
- 2004 F150 5.4 3v vacuum leak cant find!!
- Need Vacuum Diagram
- ball joints shot on 05 f150 v6
- how best to sell this truck
- Runs rough, loss of power
- Rear end
- 05 f150 alternator
- 2004 F150 Fog Lights
- Engine replacement. 5.4L 3V. Options?
- A couple of very stupid questions - oil/steering lines related
- Strange Battery light problem
- Cat Problems
- Cannot get shifter into park - 2008 F150 Lariat
- Help!! Volt guage stopped working when i had my intstrument cluster out.
- 05 f150 5.4 help
- Trans Cooler Disconnect Tool
- 05 f150 4.2L v6 oil leaking
- 05 f150 4.2L v6 reliability
- I have an exhaust question.
- Odometer not working
- Fuel problems
- 2007 common problems?
- 04 f150 4x4 problems
- Cargo light
- Doors not unlocking
- Fuse 14 blowing in reverse (ABS and BRAKE illuminate in the dash)
- Question on wheel sizes
- Need HELP - Oil coming out of IWE Vent line
- can a western brush guard for 2009 f150 be fitted to a 2008 f150?
- poor fuel millage
- headlights
- 2008 F150 Stalling Issue
- Low beam headlight help.
- Brake Controller
- Weird vibration when turning hard left or right
- Cracked FX2 Grille? Epoxy?
- 07 F150 Not turning over.....possible PCM?
- Won't start - electrical probs?
- left side actuator noise in 2wheel drive not in $wheel drive
- 2007 ford f150 5.4 217,000 miles
- Lost in Baltimore
- 4x4 light will not go out
- Flush Engine Coolant
- 2005 F-150 Power Loss and Engine Performance
- P0174 and p0301
- F150 fan clutch length??
- Dreaded blend door questions
- Fuel issue please help!
- My 04 Lariat
- Electrical Issue Truck is Dead in the water
- High mileage preventative maintenance
- 08 f150, 2 mystery wiring harnesses under dash
- Somewhere in the middle.
- Im back....! After 5 years
- 2004 F150 Differential
- New Power Steering Lines Replace Finned Cooler?
- Timing Jumped. Oil Pressure?
- Cluster Will Randomly Shut Off While Driving
- Bed bounce
- 2004 5.4L Rough Idle and No Power
- Unstable steering column
- Can I drive to the shop with no front brakes?
- More HP (2004 f150 4.6)
- 2004 F150 Drive Side Seat Belt Pretensioner
- Swapping 2004 5.4 with a 2008 5.4
- Borla pro xs
- Very odd issue with my truck
- 2004 F-150 Supercrew 5.4L 3V Engine Replacement
