Sounds and feels like abs jitters when taking off
<br />This would help explain why it's every take off even when warm, stop lights in town, etc. I was told the fluids we're changed when I purchased it. In this instance, is it preferable to drop the pan or just swap fluid?
I'm talking about the differential, it doesn't have a pan.
Does it chatter if you have the wheels straight? If so, it's probably not the issue. However, with 72k, it wouldn't hurt to change it. It takes 75W140 synthetic gear lube with a bottle of Ford XL-3 friction modifier.
Look on your door jamb sticker, what is the AXLE code? Should be 2 numbers or a letter and a number. If it's 2 numbers (i.e. 19) it's not limited slip and that's definitely not your problem.
I think you need a friction modifier in your differential. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Axle code is B6.
it does it less when the wheels are straight and a lot more when turned.
I don't believe it's the parking break, last weekend I replaced the pads and rotors on the rear axle.
Any idea what a "jiffy lube" kinda place would charge to replace the fluid in the front, rear and tranny and if this would currently the problem?
