PDA
View Full Version : 2004 - 2008 F-150
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219
  1. new engine questions?
  2. Lift, tires, and rims are installed!!
  3. Challenge for you!
  4. lighting help
  5. Leaking power steering fluid.
  6. Lost electrical power while driving...
  7. Tire Load Question!
  8. 04 xlt ticking question
  9. Tranny/diff. fluid change
  10. Electrical Issues with 2006 Ford F-150
  11. 90 octane (Pure Gas) safe on stock motor?
  12. FL 820S motorcraft oil filter doesn't fit my 2004 XL...which do I use?
  13. 2004 ford F-150 Timing
  14. Finally Back in an F150!
  15. P2104.2111,2112
  16. Instrument Cluster
  17. 2007 F150 lariat 5.4 fuel pressure issues
  18. CEL & Misfires
  19. Quick Question
  20. Rear super cab door stuck!!!! Need the correct part number...
  21. I think its VCT solenoids... and help with "rev limiter" noise
  22. 4x4 NOT working - 2008 FX4
  23. spare tire well and aftermarket tires
  24. Upper Intake Manifold
  25. Project Bear
  26. second? flare side with pocket style fender flares, check it out!
  27. Oil Leak
  28. '06 to '08 F-150 4.6L XL: Which year is best?
  29. 4in lift and 33in tires
  30. Crazy Thing Happened This Morning
  31. 07 5.4 starter question.
  32. 2006 f150 4x4 grinding noise while braking
  33. 2004 Ford F150 Fx4 No start diag
  34. Lifting My 08 F150
  35. Getting the right stance...
  36. Where to get 2008 chrome climate panel buttons?
  37. Do better tires have much of an effect on sale price?
  38. Mini Message Center help
  39. Factory remote start quit
  40. 06 Mark LT No Brake Lights.
  41. Smittybilt Predator Replica
  42. P2006
  43. Edge stage 3?
  44. Front plate removal
  45. Moving from leveling kit to lift kit!!
  46. I'm out of idea..it's not caplier or warped rotors- HELP
  47. What do you make of this? Video included "steering"
  48. 2005 FX4 4x4 intermittent
  49. What year model 5.4 3v is the most reliable? Will replace mine soon....
  50. 2005 Ford F150 5.4 3v plug change
  51. Unplugging the CPS
  52. Would You Trade Your Truck For A Volkswagen Truck?
  53. Four Wheel Drive not engauge 2004 F150 Heritage
  54. Amp Research PowerSteps are on the way!
  55. 2009 Sync installed in a 2005
  56. Transmission works fine, makes light humming sound & leaks into transfer a case. 200k
  57. Overhead front map light issue
  58. Misfire Cyl # 4
  59. Stock Grounds? Big 3 upgrade.
  60. door panel
  61. Ant thoughts
  62. 2wd lift.
  63. 2007 f-150 with 266k miles?
  64. 2004 F150 lower radiator hose problem
  65. FX4 Suspension squeaking while backing out.
  66. A work in progress
  67. New Bumpers!
  68. Air Lift Needs Your Images!
  69. Should I change the spark plugs?
  70. Silly question
  71. P2135 Throttle Position Sensor Replacement
  72. Catalytic converter code, what should I do
  73. New Wheels (MB Stryker)
  74. Vaccum Leak???
  75. Truck question... /:
  76. 4x4 Relay fuse keeps blowing.
  77. Insight on Front Bumper
  78. '05 O2 Sensor Location
  79. Code P0113 IAT sensor 5.4L 2004 F150
  80. P2135 Electronic Throttle Body Replacement
  81. engine swap
  82. Need help
  83. Interior modification?
  84. Tire & wheel help.
  85. new rims
  86. 2006 F150 lunging/walking/sputtering when braking
  87. 2006 F150 Roush Gear Swap
  88. Body Lift
  89. Location of PCV Valve
  90. 06 F150 towing
  91. Craigslist saleen grille
  92. Front brake caliper piston change
  93. New Fuel Mavericks and toyo at2 extreme's (PICTURES)
  94. K&n cai
  95. advice please
  96. Driveline problems, initially thought IWE, now thinking transfer case
  97. Front Vibration when braking
  98. to hood or not to hood, that is the question
  99. Help identify and correct problem.
  100. After replacing cam phasers...?
  101. Has anyone swapped out their 2004/2005 front bumper for a 2006-2008?
  102. GoodBye For Now. Sold my Beloved Truck .
  103. Radio volume changes
  104. O2 sensor question
  105. Need to find an engine shop in FL
  106. 200 STX Patriot Edition
  107. 2010 oem fender flares on 2005?
  108. 4.6L & 5.4L Engines Alternator Replacement
  109. installing oil pressure gauge
  110. bad ball joint - video included
  111. painting textured fender flares???
  112. she went in under the knife
  113. Running rough when slowing down
  114. Belt Tensioner issue
  115. stalls/idles bad after changing coils/plugh
  116. Power Steering Pump Endplay?
  117. 2006 F150 Horrible Idle!
  118. Front Wheel Grinding...
  119. reverse not working 100%
  120. Battery drain
  121. Going to Change upstream O2's
  122. Odd issue started yesterday
  123. Do i have a bad spindle?
  124. looking for the connector for the parking lights on 2004 F150
  125. Towing Reality?????
  126. 2007 F 150 Super crew Tires
  127. New-to-me F150
  128. Chris fx2 build thread
  129. Cruise control and right turn signal issue
  130. 2004 F150 making horrible noise when i let off of gas or hit the brakes
  131. F-150 emblem question.
  132. Some recent pics of my 04
  133. Started smoking again today..
  134. Timing chain 5.4L
  135. Motorcraft FL-1A oil filter on a 2006 4.6?
  136. Door Lock Rod Clip Help
  137. Finally
  138. Everyone likes pictures right?
  139. who drives an f150 heavy payload pkg with 4.10?
  140. Where does this go?
  141. Tailgate Spare Tire Lock
  142. I got a P0463 code - Fuel Level Sensor A Circuit High
  143. P0345 and P0349
  144. Help with touching up some places
  145. Please help: rough running 5.4 many cylinders not firing
  146. '04 F150 key wont work
  147. New truck mod suggestions
  148. best rim & tire size on 4" lift
  149. F150 Steering Binding on Turns
  150. Standard shop hours to change plugs on an '06 4.6 F-150?
  151. 2004 5.4L 3v F150 - rough idle and stall once warm
  152. Whipple Supercharger help
  153. Shudder when down shifting out of overdrive under load
  154. High quality replacement headlight housings.
  155. fixed squeeling hub
  156. 2004 FX4 s-crew custom hidden winch
  157. 4X4 Inoperative Diagnosis No Tools Required
  158. F150 4X4 Inoperative and Noisey
  159. Blue fuel line retaining clip broken
  160. 2004 speedometer issue
  161. 5.4 liter replacement
  162. New paint & LED light bar, bye bye two tone.
  163. successful sparkplug change, but...
  164. 5star Tune Question
  165. 2008 F-150 4.6 overheating and no heat.
  166. 06 5.4 3v Noise When Starting Only.
  167. my engine shakes alot
  168. Got some new toys!
  169. Cowl Gap
  170. Led conversion to blue interior need help?
  171. 4.6L 5.4L Power Steering Type Whine Noise
  172. weird sound
  173. 3.5" lift kit
  174. 2004 lariat power back glass and moonroof
  175. 4.6L vacuum gauge readings?
  176. may have solved the problem...
  177. 5 min. trips
  178. How To: Shift Console Assembly and Repaint
  179. Newbie needs help, dreaded p0174 code
  180. New Terra or Trail Grapplers???
  181. So I need some advice on what to buy.
  182. TPMS system
  183. loud buzzing noise
  184. Back with another F150!
  185. Dome light problem
  186. highfly24's build thread - 2004 Blazin' Yellow F150 FX4 "Big Bird"
  187. vibration
  188. 04 Supercrew questions
  189. Need Help Quick, Overdrive Switch
  190. MPG with Airaid MIT
  191. How many miles from a tank of gas???
  192. 4.6 vs 5.4 throttlebody
  193. So I took my truck to the dealer......
  194. how to trim plastic fenders?
  195. Speedo ?
  196. pressure decal
  197. Temp Gauge Tweaked
  198. 2005 f150 lift kit?
  199. 4x4 Problem ESOF
  200. 4X4 grinding on decel
  201. rocker arm/cam follower
  202. Driveshaft
  203. Fuel Level Low even with 3/4 of tank full
  204. Factory Skid Plates ?
  205. Baticus's 06 Supercrew build...
  206. Running board question
  207. Most recent 5.4L 3V spark plug change TSB?
  208. Hunting and gathering...
  209. Rumble noise in 4x4 at speed.
  210. 2005 Ford f150 - clunk noise and sputter when full throttle
  211. 2nd spark plug change or is it a transmission?
  212. OEM Antenna
  213. 2008 F150 Lariat Stalls after warm up
  214. Wheel/Tire Sizes
  215. Crank No Start P1233 Fuel Pump Driver Module
  216. Power Steering Pump Replacement
  217. LED Light Bar
  218. total elimination of gas smell after spark plug change
  219. Carbon in head
  220. Saw my old truck today!
  221. 2006 f150 power steering?
  222. 2006 f150 V8 5.4
  223. Black box - Factory installed GPS
  224. No heat....just cold and less cold!
  225. Fuel Filter Canister
  226. Rancho QuickLift Loaded / Coil Sumo Springs combo.
  227. Ranch Hand Grille Guard Installed
  228. Looking for tires that fit
  229. Water in front differential
  230. How Much $$$
  231. 4 Way Trailer Connector
  232. One of the many sounds of my truck WITH VIDEO!!!
  233. Fuel pressure test
  234. random stalling
  235. New Used Truck here, looking for a few tips
  236. COP'S From Ebay
  237. New Old 2005 Ford F-150 King Ranch
  238. 2007 5.7 oil leak question.
  239. Aftermarket Remote Start 07
  240. Ring gear bolt backed out
  241. Tire size
  242. Burn smell from truck only after driving up hills
  243. Transmission Line Cooler Replacement
  244. 2008 Ford F150 4x4 transfer case question
  245. weight for snow
  246. Leveling kit & rancho quick lift????
  247. Another Year...
  248. lower or raise
  249. My blank canvas
  250. Westin Brushguard Installation Help
