4.6L vacuum gauge readings?
Old Jan 29, 2014 | 06:37 PM
hermangarza1987's Avatar
Post 4.6L vacuum gauge readings?
Hi,
Does anybody else have a vacuum gauge installed in their trucks? I keep getting 0 at 2000 rpm and stays there for a few seconds. Has anybody else had this problem before?
Old Jan 30, 2014 | 10:28 AM
SoonerTruck's Avatar
Where is it at idle?
Old Feb 4, 2014 | 07:52 PM
At idle it reads 17 to 22 but on the highway for the most part its on zero until it decides to drop till 10 at cruise control at 65 mph. I have noticed it takes a while for the torque converter to lock?
Old Feb 5, 2014 | 01:00 AM
You probably don't have it connected directly to a manifold vacuum source, it sounds like it's going through some type of solenoid or switch.
Old Feb 10, 2014 | 01:30 PM
Yes you are right, I have it in a tee connection to a line running to the iwe solenoid on the passenger side. What would be the best line to connect it to?
Old Feb 10, 2014 | 04:36 PM
Something that goes DIRECTLY to the intake manifold.
Old Mar 2, 2014 | 09:13 AM
IntRiniTy's Avatar
brake booster???
i too hooked it to my iwe line after the one way valve, i thought it was my vac gauge that was bad.
