installing oil pressure gauge
To all that have check oil pressure with an after market gauge, what did you do to get the fittings or sensor installed? I to a quick look at ours and I can't get my hand into the sensor because of the front diff & motor mount. I want to check the oil pressure on ours because we have the knocking, stalling at idle after warm, & code P0340. Since we got it the week before Thanksgiving, I have replaced the plugs, fpdm, vct solenoids, cam sensor, crank sensor, fuel filter, oil & filter. The stalling at idle after warm started like someone flipped a switch (not sure what happened). I have been told and read the knocking is the cam phasers.
I got this done temporarily to check oil pressure. I used a long extension and a swivel to take out the factory oil pressure sensor and instal the fitting for the mechanical gauge. To tighten the line i reached up in front of the diff getting my fingers & wrench behind the filter drip tray. Had to keep flipping the wrench around to get the line tight. The I ran the line inside through the plug in the firewall to the outside behind the exhaust.
http://www.obd-codes.com/p0340
Your code indicates Camshaft Position Sensor Circuit Malfunction.
You may have a sensor that has gone bad, or a plug that has come undone...
Very strange you say something about the stalling and knocking like ticking at idle when coming to a stop from riding on highway or something, that is how mine acts and it seems for no reason, it did not do this till i changed my cam phasers, and timing chains, but i rev the engine and it goes away if you figure it out please let me know
I have read where similar rough idle and stalling was caused by one of the cams being out of time by 1 tooth. I have not pulled the timing cover to find out. I don't have a garage to work in and didn't get the cam phasers, tensioners, and guides yet.
If I figure it out, I'll certainly let you know. If you figure it out, please let me know.
