PDA
View Full Version : 2004 - 2008 F-150
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219
  1. Another gas gauge thread?
  2. Crank no start. No Rpms
  3. Dash Removal
  4. 2005 5.4 start and stall almost immediately unless I give it fuel
  5. Cranks but won’t start
  6. Tps
  7. Flow Through Cable issue
  8. Installed center console 08 Regular cab
  9. Overhead console options for Regular Cab 04-08?
  10. My Intermittent misfire fix 2007 5.4 3V/ warped air filter tray
  11. Bigger tires, stock truck
  12. 2007 F150 XLT, 90K miles "chirping"
  13. 2008 f150 5.4
  14. airbag code 3-3
  15. 2007 5.4 3v intermittent tapping around converter
  16. airbag code 3-3
  17. Transmission trouble
  18. Replacement console latch
  19. Fail safe mode P2104 & P2112
  20. Lets see those Vermillion Red trucks.
  21. P0354 code for 2007 5.4L 3v help needed
  22. Rip
  23. No dash lights, clearance lights, taillights
  24. My 4R75W transmission issues and result
  25. intake manifold coolant crossover leak
  26. 5.4 2v in o4 to o8 installed no CEL
  27. P0020/p0021
  28. 2006 Ford F150 XLT 5.4L v8
  29. I need help with concerting my 04 f-150 to a 4x4
  30. F-150 mud machine with engine in the back
  31. 2008 F150 - Cruise Control Not Working...
  32. 2004 f150 timing chain cover
  33. 04-08 Regular Cab questions for a Fly & Drive adventure
  34. 2006 F150 Over cab brake Light Won't turn off
  35. I’m new to this. Code P0012 P0345
  36. Oil Filter Noise
  37. Timing chain slap/tick/ knock
  38. engine change
  39. Been a while y'all!
  40. P0305, P0306 flashing CEL. All ford new plugs, cops, etc
  41. Considering buying my first F150. Can y'all give feedback?
  42. Buyer Beware - Go Rhino 3000/3289 for 2006 - 2008 F150
  43. New Shoes - Cooper ATP 275/65/18
  44. Does anyone know what this button is on my 2005 lariat?
  45. How to Wire in Power Points - 2003-06 Expedition Center Console Swap
  46. 05 5.4 cold weather woes. Ideas?
  47. My cam Phaser nightmare.....
  48. 2004 Lariat Sun Roof
  49. How to Remove This Connector?
  50. Inexpensive 3" tail-pipe
  51. No airbag lights but 5x5 bell/chime
  52. Gen Question about Wiring Harnesses
  53. 2007 F150 odometer light replaced finally.
  54. 2006 f150 fm radio volume real low
  55. 5x5 warning beep. Airbag lamp out?
  56. 00-ish 4.6 swap into 05 4.6
  57. Looking to give away 04 F150 items
  58. Idles rough when warm
  59. intermittent alarm
  60. Raptor 4" Nerf Bars are on 2007 reg cab
  61. 2006 f150 motor swap options
  62. 2004 f 150 5.4 running issues
  63. MBRP Cat back
  64. Battery on 05 F-150
  65. 2004 XLT 2wd front end noise
  66. Four and seven pin plugs
  67. Wiring issues
  68. What wheels do you recommend? FORD LOBO FX2 2008
  69. Help Won't start
  70. spacing between cab and bed2007 f150 supercrew xlt
  71. Blown head gasket
  72. 06 Mode Door Actuator
  73. Reduced Engine Power and false oveeheat?
  74. DIY Roush Vent Pod
  75. New Pirelli Scorpion ATRs
  76. Power Steering Removal
  77. 2007 F150 super crew door window
  78. 2007 ford f150 supercrew.
  79. Auto lock loses it’s memory
  80. P0325 & P330 and Pinging
  81. Burning smell, cant find a possible source.
  82. 04 Ticking in Park but Not Drive
  83. Aftermarket HP upgrades
  84. Timing job and other maintenance
  85. Need some help with issue
  86. Lighting issue driveing me crazy
  87. I'm trying to get insight for my build.
  88. 2007 F-150 died while driving
  89. wix oil filter
  90. Trying to determine value of my truck.
  91. Ball Joints and Leveling/Lift
  92. FR75W Tranny faults and warrantee advice needed
  93. My plugs going to start popping out of heads one day? 2004 4.6L Triton 62K miles
  94. changing stock 20s to 18" methods
  95. RADIO SWAPS on 2006 F150
  96. 2007 Center console hinge snapped. Help
  97. P0340 2006 5.4l 3v
  98. Heated seats
  99. ¿285/60R18 tires on my F150 2008 4x2?
  100. Fender flares to cover rust?
  101. Correct Fuel Pressure for a 2007 4.6
  102. Key Question
  103. Where is the best place to put the light bar on my F150?
  104. 2005 Ford F-150 Lariat 5.4l 2wd NASCAR Edition
  105. 2008 Suicide doors are both stuck shut
  106. Slow startup when cold
  107. How to disengage from 4 low?
  108. How to neutralize backup alarm?
  109. Misfire shudder
  110. Left signal cuts off cruise
  111. small radiator
  112. 2006 5.4l true dual
  113. 2004/2008 fuel pump ground problems
  114. Problem filling fuel tank after fuel pump replacement
  115. 08 4.6 engine stand bolts
  116. Drivers seat noise moving forward or backward
  117. Transmission swap
  118. Fuel
  119. my #14 fuse keeps blowing
  120. 2006 STX trade in value.
  121. 4x4 Hubs - Vacuum line and Vent Line
  122. 2005 f150 4.6 Vacuum line issues
  123. Need Electrical help!!!
  124. 06 5.4 Auto FX4 transmission
  125. 05 to 04 engine swap
  126. Intermittent A/C 2005 F-150 KR
  127. 2005 f150 oil pressure drops and engine knocking.
  128. 2007 f150 no crank issue
  129. Window Switches .... again?
  130. Pressing Wheel Bearings?
  131. Cold Air Intake...
  132. Orifice Tube Replacement
  133. Help ... porcelain & electrode left
  134. door lock issue
  135. 08' FX4 Ext. Cab needs coil springs
  136. Call me crazy
  137. 2007 5.4L Misfiring
  138. Coolant leak/pour as water is poured into res...
  139. Dashboard Trim Removal?
  140. A.c. clutch not engaging all the time
  141. Oxygen Sensor and Cat
  142. Dash Cover Mat
  143. Outer Door Pillar Piece
  144. Stuck in 4x4 high
  145. 2005 stx 6 lug 4wd rear differential size
  146. Mother of all electrical problems 08 Lariat
  147. 04 f150 front 4x4 hub problems
  148. Preventing the cam phaser issue?
  149. Ac not getting cold
  150. IWE (I have already read diagnostic threads and know the problem)
  151. Accurate oil pressure gauge?
  152. Removing Vehicle Security System
  153. Headlights question for y'all
  154. Hello from Edmonton, Alberta, Canada.
  155. Hello, please help with codes
  156. A.c. checked good with gauges, Freon level good. Blowing air not hot or cold
  157. Dead Radio
  158. Top Tier Gas
  159. 2006 Keyless entry
  160. Cv axel vibration
  161. 200,000 miles!
  162. Color of original 5.4 3V COPs?
  163. SP515 vs SP546 plugs
  164. Non-functional cruise control
  165. P0720 code
  166. Please help! Drivers timing chain won't stay tight
  167. Motorcraft fuel pump driver modules
  168. LED turn signal hyper flash problem
  169. Custom intermediate steering shaft
  170. Gas mileage.
  171. Alignment
  172. Whining noise front of engine 2008 5.4
  173. Bolt pattern
  174. 06 F150 XLT Brake Light Issues
  175. Having trouble
  176. Should I sell my 2006 5.4?
  177. Intake Manifold Upgrade
  178. It's probably not the tranny, what I learned
  179. 2006 4X4 limited slip rear servive question
  180. engine pink after tune up
  181. 2006 King Ranch F-150 power windows
  182. Misfires while backing up
  183. 4x4 wont engage
  184. 04 F150 Fuel Pump test
  185. Parking Brake Rivets
  186. Timer for exit lighting 2006 XLT????
  187. '06 4.2 Crankshaft Position Sensor
  188. Changing seat pad adding seat heater?
  189. 2007 Trans Fluid Leak
  190. Upgrading Double DIN Radio to something more modern
  191. Rattle noise
  192. Rough running new engine
  193. Wheel bearings?
  194. No start...no power to fuel pump
  195. Sloppy rear end
  196. Issue with my information reset button
  197. Installing new Chrome bumper on an 05
  198. starter top bolt
  199. Hood Mounted Pod Lights
  200. 2008 interior light on/off by itself
  201. 1100 rpm rough
  202. 04 f150 5.4l runs for a few seconds then stalls out
  203. P1000 / Edge Evolution CS / Emissions Inspection (NJ)
  204. 04 fx4 f150 stuck in limp mode
  205. 2004 5.4- Black smoke, stalling, hard to start
  206. Weird brake issue
  207. Transmission issues.......
  208. Best experience with rotors 2005 F150 RWD
  209. No power in reverse
  210. 2004 f150
  211. Light Throttle Misfire - Solved
  212. fixed door rattle on my SCAB
  213. 2004 F150 No injector power
  214. P0325 CEL When Towing?
  215. Removing armrest help
  216. 2007 f150 4x4 hard to steer
  217. Brake Pad Advise
  218. 04 F150 4WD Front Tire wear
  219. 2008 front "grinding" noise
  220. 2004 f150 Passenger side Exhaust Mainfold
  221. Should I take a gamble?
  222. Making or buying splash / water Cover for COP coil plug area 04-08 f150 4.6 ( misfire
  223. Stripped bolt for swaybar-to-frame bracket
  224. 2004 F150 Headlight Beam staying on
  225. wich boots?
  226. Torque Converter (4R75E)
  227. My steering wheel makes a popping noise!
  228. Transmission trouble
  229. Help Diagnosing AC/Heat Being GONE!
  230. Bank 2 issues MPG droppedd to 13 and has errors
  231. Saleen S331 Blower Needed
  232. Need Towing Advice TODAY
  233. Power drop....and then oil pressure drop when warm
  234. 2004 F150 XF4 Offroad Airbag Lights
  235. Anybody running new OEM rims? Pics please
  236. Newbie with a Programmer
  237. rack and pinion seal
  238. Does your truck die when it rains?
  239. Strange electrical issue
  240. 2004 f150 BW 4406 transfer case swap with 06
  241. 08 f150 5.4 swerve on highway
  242. 08 4.2 misfire
  243. pcm
  244. 2004 f150 4x4 shakes when in 4 high
  245. 2005 f150 fx4 5.4 limp mode
  246. truck wont start, clicking when key in ignition all electronics dead
  247. Power Folding Mirror Install INSTRUCTIONS
  248. forever on headlights
  249. 05 5.4 PATS issue? crank, no/intermittent start. Lots done!
  250. 2007 f150 electrical gremlins
