2004 F150 No injector power
on
Follow the red wire back. There's an open circuit between the injector portion of the harness and the splice (S103) that taps off power for the PCM. There's an inline connector, C136 pin 3 that is in that run. C139 is on the passenger side rear of the engine compartment and is a square 12-pin connector. That would be both a suspect connection as well as a convenient location to half-split the circuit for testing.
