I知 new to this. Code P0012 P0345
Old Feb 7, 2020 | 11:11 AM
Pk1's Avatar
Pk1
I致e had this ticking sound since I bought this and I致e heard about cam phasers but hoping it could be some other issue. I致e bought this truck with 217,000 miles I got a good deal on it. Replaced spark plugs, coils, Vct solenoids. I had a loss of power as I was accelerating around 25 mph. It felt like it didn稚 wanna go. Drove it for awhile but one day It started running rough when I went to turn one day after driving 30 mins, I had these two codes pop up so I erased them and replaced the cam position sensor bank 2. The ticking stopped so I went to go take it for a drive and not even 2 minutes into driving it, the check engine light popped on then off and my car stopped running. I turned it completely off and started it again but ever since this ticking noise came back again and I drove it for about 5 mins and it drives like it did before. Any suggestions would be appreciated. Thanks
Currently running 5w-20 for oil
Old Feb 7, 2020 | 11:45 AM
Pk1's Avatar
Pk1
Link to the noise
Hoping this is just the fuel injectors
Old Feb 7, 2020 | 12:12 PM
That's not injectors. Good chance you need to replace the whole timing set and put in a high volume oil pump. 4 part video followed by parts list:
These are the Tools and Parts needed for the job:
Ford Timing Chain Set-
http://amzn.to/2asW4BM
Valve Cover Gasket Set: 2004-2007-
http://amzn.to/2ao6KB7
Latest VCT Solenoids- http://amzn.to/2aZtAo5
Crankshaft Pulley Bolt-
http://amzn.to/2aNQwRL
Phaser Holding Tool-
http://amzn.to/2aBVfpK
Roller Follower Remover Tool-
http://amzn.to/2aDglu5
Crankshaft Positioning Tool-
http://amzn.to/2ap8eOD
Cat Claw-
http://amzn.to/2anM8yV
Crankshaft Pulley Puller (2004-mid year 2008)-
http://amzn.to/2akfw3k
Pneumatic Fan Wrench Kit- http://amzn.to/2auxqmP
Permatex Engine Sealant-
http://amzn.to/2anMrtp
Lisle A/C disconnect tool-
http://amzn.to/2aaYpW3
5W-30 Oil I recommend-
http://amzn.to/2aeRdUt
Melling M360HV Oil Pump-
https://amzn.to/2IBcqKG
Engine Coolant needed if drained-
http://amzn.to/2aeR6bh
Mopar Rust Penetrant- http://amzn.to/2anN8D7
Oil pump replacement Video:
Something else you need to check:
Old Feb 7, 2020 | 12:31 PM
Pk1's Avatar
Pk1
Thank you. Also I致e heard good things about the lockout kit but I知 not sure
Old Feb 7, 2020 | 02:16 PM
Roadie's Avatar
Another interesting video about the p0345 code.
