4x4 Hubs - Vacuum line and Vent Line
Old Aug 14, 2019 | 04:29 PM
Jesse Brauner's Avatar
Hello all. The vacuum lines were redone on my truck, but I notice that both the lines going to the hubs are under vacuum. From my understanding one of them should be a vent. My question is the small hose or the big hose the vent? Much appreciated.
Old Aug 14, 2019 | 07:01 PM
tbear853's Avatar
If you pulled them one at a time, leaving the other hooked up, and hear a hiss, normal as vent is closed.
The vent valve I not at the IWE, it's a valve at the other end of the vent hose, so vacuum will be the same in both hoses at the IWE.
Old Aug 14, 2019 | 07:36 PM
They should only be under vacuum when you are in 2wd and the engine is running.
https://www.f150online.com/forums/ar...then-some.html
Post #3 may help.
Old Aug 15, 2019 | 12:00 PM
Figured it out. The larger tube is Vacuum and the smaller one is the vent line. Thank you.
