Transmission trouble
I just had my transmission rebuilt and im still having issues. When it says its in park it is, but will only drive in neutral, first, and second. what could be going on all the clutches are good and the torque converter is new?
Go back to the shop and ask them if they even bothered to look.
Your shifter positions are independent of the transmission selector adjustment >>>at the transmission<<<..
Slop in the linkage or cable hardware and shift position indicator in the dash.
Good luck.
Good luck.
Here is a link to shifter cable issues in older F150. It might still apply for you. I fixed mine with a simple zip tie (last post in thread)
https://www.f150online.com/forums/19...ce-needed.html
