Motorcraft fuel pump driver modules
Do you mean the module has been updated ..... or are you just referring to the use of standoffs or spacers to get it away from steel crossmember?
What I did wirh my '07 back in 2010. Mine was just mildly corroded, I cleaned it, clear coated it, added spacers and longer bolts. If mine was nearly in halves like some, or had a hole in it, Id replace it then.
My OE FDPM was still in good enough shape that I was able to clean it up, lube it and add my own spacers. It has been doing fine for over 5 years now. I do keep a spare ready to go just in case, though.
https://www.f150online.com/forums/ot...-question.html
I used some longer 6mm bolts, cut heads off to make them into studs, screwed into frame, then followed with a nut to serve as jam nut and spacer, slid washer on, put FPDM in place, and finished with 6mm nyloc nuts and washers.
