04 fx4 f150 stuck in limp mode
Old 04-20-2019, 08:16 PM
Billy Winfrey's Avatar
Throwing codes for
right front wheel speed sensor input circuit failure (c1145)
left front wheel speed sensor input circuit failure (c1155)
wheel speed rear input signal missing (c1237)
fault received from external node (u2023)
iwe solenoid circus failure (c1979)
Also throwing p1000 off system readiness test not complete
truck was was going down the interstate after 200+ miles for the day and just went into limp mode with not much warning
abs light is on
any help is appreciated
Old 04-20-2019, 09:33 PM
Have your alternator tested.
Old 04-20-2019, 10:08 PM
glc is offline
No P-series codes?
Limp mode usually means a electronic throttle issue. Your C-codes are ABS codes.
P1000 means all the sensors haven't achieved readiness since the last battery disconnect or code clearing.
Old 04-22-2019, 11:13 AM
No p series code other than the one stating it’s in limp mode
Originally Posted by glc
No P-series codes?
Old 04-22-2019, 02:14 PM
glc is offline
What is the exact P-code?
Old 04-22-2019, 03:26 PM
p2106
Old 04-22-2019, 03:27 PM
I’m thinking my abs module is bad or shorting out somewhere ... only thing I can come up with
Old 04-22-2019, 03:30 PM
glc is offline
Old 04-22-2019, 04:00 PM
I have ... it’s reading a failure somewhere in the diagnostic system and throwing that code ... that code is the “limp mode code” to alert you that the system is in fail safe
Quick Reply: 04 fx4 f150 stuck in limp mode
