Brake Pad Advise
Brake Pad Advise
I have a 2006 5.4 SCab, replaced the brake pads and rotors several years ago and now have about 35K on the pads and rotors, and the pads are just about gone. They are EBC Yellow pads. The truck is used as a daily driver and sees combined city and freeway driving and I was expecting a bit more from the EBC pads. From a performance standpoint, I haven't been too happy with the EBC pads, pedal has been softer than the original pads , despite several brake bleeds using a pressure bleeder along with brake fluid changes. And the braking performance hasn't been any better than the OEM pads. I'm using the Centric 2 piece hub/rotor assembly and have had no problems with them.
Anyone have a recommendation on brake pads? Thanks, John
I rank them this way:
1. Wagner Thermoquiet
2. Powerstop
3. Motorcraft
All 3 are good replacements. Even Motorcraft neck and neck with with Powerstop in my opinion. Reason I like the Wagner Thermoquiet is barely any brake dust. But on the vehicles I've installed them on, there is brake fade when towing.
As far as braking performance, the only "seat in the pants" feel you'll get is with larger calipers and rotors.
When I replace folks brakes on Ford vehicles, I stick with Motorcraft -- as I get consistent results.
2. Powerstop
3. Motorcraft
I've used the Centric 2-pc rotor on my F-150 and Powerstop Evolution pads. No complaints here. As far as "brake pedal feel", I doubt the pads have much to do with that. I'd imagine the biggest change in feel you can make, short of changing out calipers/rotors to a bigger brake kit, is to get SS braided lines to replace the rubber hoses at each caliper. The SS braided lines don't allow the aged factory rubber hoses to expand under heavy brake pressures and will result in a better "feel" from the brake pedal. It's not going to be world-changing, but it will offer a less spongy feel.
Ceramics act as insulators and thus leave more heat in the rotors, they have less grip when cold, wear rotors more. Large reason brake rotors are larger these days.
Couple years ago, redoing brakes on a car, I went with ceramics …. and within a week had removed them to put faster acting metalics on. Difference was noticeable.
I put a set of ceramic pads on the '04 I had and they came with a disclaimer in the box saying they weren't recommended for use towing trailers or carrying heavy loads. They kept my wheels clean, but they had noticeably less stopping power. I replaced them after a scary situation with an emergency stop.
Got the pads and front rotors changed. One of the front pads had a piece of steel embedded in it and that was causing most all the noise. It also cut a groove in the rotor. On the rears, pads were good but one of the caliper pins/bolts had seized and caused one of the pad guides or what ever they are called, to slide out of position and it was hitting the inside of the wheel. A quick trip to ORileys got me a new brake hardware kit, lubed it all up and it now stops as good as new.
