2008 Suicide doors are both stuck shut
Old 09-03-2019, 02:55 PM
EJHF150's Avatar
Can’t find any instructional videos on how to even remove the door panels. Does anyone have some info?
Old 09-03-2019, 03:15 PM
jgger's Avatar
The upper trim should be snap in, wiggle and pull. That should expose maybe 2 fasteners plus maybe a screw in the interior grip or not. Then if like other models LIFT the panel out.
This is a guess based on my 03, it should be similar. If the windows are not roll up and down then the latch may need to be removed. I did a write up for the 03 but it didn't make it into the DIY section. You can check SCAB rear door stuck-fix
The following users liked this post:
Old 09-03-2019, 09:11 PM
Roadie's Avatar
If it is like my 02, the plastic cable housing end breaks and won't hold the cable and it won't pull the latch. I fixed mine twice with new ford cables the first time at a cost of over $200 and the second time I fixed them for less than $10 with these available on ebay.
https://www.youtube.com/watch?v=HGcJ...ature=youtu.be
Old 11-02-2019, 11:07 AM
60DRB's Avatar
Indeed.
I was about to do the $100 per side cable replacement and came across this video.
https://www.bing.com/videos/search?q...502C&FORM=VIRE
Did both my doors a couple weeks ago, and saved a bundle. This guy shows door panel removal as well...one stop shopping for the full repair.
Just make sure the cables are free to slide inside the metal replacement ends. Mine were a little snug and needed some filing, or you could spread them a little instead.
Quick Reply: 2008 Suicide doors are both stuck shut
