Best experience with rotors 2005 F150 RWD
Hello,
Outside of paying big bucks for new motorcraft rotors on my 2005 F150 STX RWD, I opted to be in the middle and have bought a few sets of AC Delco. I just wanted to see what brands everyone else has been using with good luck? The front rotors on mine have the hub included so not a lot of options for places to turn them, it just seems like I don't have these AC Delcos on for more than 10K and i'm back to pulsating again.I would like to venture to a different brand to see if they last longer.
Centric rotors, Powerstop pads. I have a 2WD as well, but I went with the 2-piece hub/rotor conversion hit last time I did the front rotors, so that it uses the 4WD version. Benefit is just that the rotors and hub are separate and you can install new wheel bearings at that time if yours are original. No more messing with 2WD front 1-pc units and pressing in bearings.
Centric Conversion Kit (Part 120-65128) includes (1) front rotor, (1) hub assy/bearings, (1) nyloc spindle nut and runs about $140, so double that to do front brakes.
I used Centric rear discs as well, but those are the same as 4WD I believe.
