New Power Steering Lines Replace Finned Cooler?
Ordered new power steering lines for my 2005 Ford F150 4.6l 2WD. This turned up yesterday afternoon. A few threads have suggested that this is supposedly a revised design which replaces the finned power steering radiator/cooler with just a length of pipe, although no one has confirmed this.
Am I OK getting rid of my original finned cooler for this 'revised' design? Or do I risk overheating issues?
Like for like replacement lines do seem to exist which means I can keep the finned cooler, but I couldn't find any OEM Motorcraft ones, only aftermarket.
You should be able to find just the hose from Tasca Ford Parts. That would allow you to keep the cooler.
https://www.newegg.com/Product/Produ...9SIA9Y43VP2866
Can't say if it's a required piece of equipment to have the cooler but it can't hurt. I'd want the cooler, not that the fluid is subject to any combustion temps but the power steering pump is attached to the block which will transfer heat to the pump and to the fluid.
Where's the sensor located?
That's the wrong pipe . . .
Hello, hope it's not too late to reply to this thread.
I believe you've got the wrong part. I'm replacing the return to reservoir hose on my 2008 F150 5.4 and the part you're showing that looks like a trombone slide is the part that returns fluid to the reservoir.
I just bought it today at advance auto and when I saw your picture it's exactly what I have in my hand. The original part number is: https://shop.advanceautoparts.com/p/...771/11053294-P
Okay, I don't know the exact part number could I keep getting lost trying to find it online, but if it looks like the part I'm referencing and the web address above, that is not the finned cooler that you have, you have the line that is returning to fluid to the reservoir. I'm replacing mine right now.
Whether this helps or not I don't know, I just know that soon as I saw that part I recognize immediately. Best of luck.
Jerry
Look here, this is the pipe you have, I think. . . Ford Part No.: 5L3Z-3D746-A
https://www.fordpartsgiant.com/parts...eering,,3D746B
Jerry
