Which Phasers
Which Phasers
So ill be in the market for some new cam phasers this spring. OEM are so expensive so i was looking into an alternate. Dorman have HORRIBLE reviews so who has aftermarket that are holding up?
or can someone recommend a complete kit with phasers, solenoids, chains ,sprocket, tensioners , etc.
do the whole front at once. i hear there are updated tensioners. i would like to overhaul the front end
just to make sure. as said above .someone has done this. any help appreciated.--irv
So Irvin, since we are the only ones interested in this, I'll let you know my plan. I believe that the reason some of the aftermarket phasers dont last is because of lack of oil pressure at idle. Our trucks are known for this. There is an entire kit on amazon for around $185 with no bad reviews. Im going to do the whole front and plus put in a melling 360 oil pump to fix the oil pressure issue. This should, hopefully, be a lasting repair. Good luck to you.
