Lower ball joint space
Old Oct 8, 2017 | 10:51 AM
Recoil9's Avatar
Just replaced upper control arms and lower ball joints. I noticed there is a gap in lower ball joint connecting the lower control arm to wheel assembly. I torqued to proper spec and wondering if this is normal. Will it shift up once the wheel is on and truck back on the ground?
i tried lifting control up with a jack but can't get the bottom piece to shift up anymore.
Old Oct 15, 2017 | 11:59 AM
sctptetwn's Avatar
Mine did the same. I replaced 1 year ago and everything is fine.
