35x12.50x17 plz help
Old Apr 6, 2011 | 07:47 PM
infantry_18's Avatar
im puttin a 2.5 in spacer lift in the front and a 1.5 in rear block lift in my 2007 ford f-150 xl. can i clear a set of 35x12.50x17 pro comp radial mud terrains? no one can seem to help me on a answer.
Old Apr 6, 2011 | 08:03 PM
May have a little rubbing on the control arm when turning if they are on stock wheel's and that's assuming the truck is a 4x4.
Old Apr 7, 2011 | 07:19 PM
Burke's Avatar
You should be able to clear them but there is going to be some rubbing. I got a set of 315/70/17 Mickey Thomson MTZ's on pro comp wheels with a 2.5 inch HBS spacer and they definatly rub. I had to trim the plastic on the inside of the wheel well and a little on the bumper. It only rubs sometimes on the control arm at full lock but not often.
Old Apr 8, 2011 | 06:47 PM
yea i figured it would rub, im probably gonna just go with 305/70/17 buckshot mudders
Old Apr 9, 2011 | 02:24 AM
noregrets's Avatar
I have 35x12.50 r20 and they rub but not too much only on full lock in reverse going over a bump...Lots of people are running that combo on stock 17's they will rub but it will be minor...
