Tapping noise
Old Dec 31, 2014 | 06:20 PM
Tommy Johnson's Avatar
Tapping noise
Recently I had a misfire on cylinder1 Found out the coil was bad. This cause the O2 sensor on bank 1 to show bad (stuck rich). When I moved the truck to replace the O2 sensors I started getting a tapping sound from the engine. The oil and filter had just been replaced. Oil is full.
My question is could this be a lifter or something else. Oil pressure shows good. Can't pinpoint were the noise is coming from. Thought maybe the alternator or pulley.
Old Dec 31, 2014 | 08:39 PM
What year and which engine? Not a Fram filter is it?
Old Jan 1, 2015 | 12:57 AM
MGDfan's Avatar
2005 5.4 3V
==> https://www.f150online.com/forums/20...5-f-150-a.html.... (to which you never bothered to reply)
The O2's are NOT bad - they are doing their job trying to tell you something is wrong on Bank 1!
Also read: https://www.f150online.com/forums/v8...-problems.html
Post. All. The. Codes.
Recommend you just take it in - yer obviously out of yer depth troubleshooting this.
Happy New Year.
MGD
Old Jan 1, 2015 | 05:17 AM
Sorry MGD. My wife fell been trying to deal with that and the trouble with my truck at the same timei
Old Jan 1, 2015 | 05:27 AM
Here are the codes I got after replacing the coil
P2196 Oxygen Sensor Signal Biased/Stuck Rich Bank 1 Sensor 1
P0300 Random-Multiple Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0316 Misfire Detected on Startup (First 1000 revolutions
P1000 On Board Diagnostics II Monitor/Drive Cycle Test Not Complete
Old Jan 1, 2015 | 10:14 AM
MGDfan's Avatar
Hey.
Sorry aboot the wife - hope she's okay!
Those codes can be indicative of leaking injectors, which the other thread elaborated on.
Or - it could be valvetrain-relaetd as that link explains.
Left unattended, it can severely damage the engine. Taking it in to get them checked may in fact be yer best recourse.
Best of luck!
MGD
Old Jan 1, 2015 | 10:55 AM
Thanks MGD.
After it started tapping I knew it was over my head. Sad part it's a 2005 with 130,000 miles on it and I've never had a problem with it. I've got a friend that works on Fords. He wants me to leave it here and he will come by and check it first.
Will update after I find the problem
Old Jan 1, 2015 | 01:22 PM
Good news I hope.
A friend of mine came by and the guy with him works on Fords.
First thing he did was disconnect the battery. waited 15 minutes and hooked it back up. Restarted the engine and had NO CODES. Ran engine for 15 minutes.
He checked the tapping noise (with a long screw driver). Said it could be one or both cam phasers or the timing belt Said it would be about $200 for both cam phaser and a $100 labor. If its the timing belt could cost about $2000
Old Jan 3, 2015 | 01:50 PM
You don't have a timing belt, it has chains.
Old Jan 4, 2015 | 10:35 AM
What's the average cost for parts and labor to replace the cam phaser
Old Jan 4, 2015 | 11:43 AM
MGDfan's Avatar
Hey.
Depends on whether the front cover is to be removed or not - labour goes way up in that case. And it typically needs to come off to inspect guides and tensioners.
We've got a few techs here who could supply costs and shop rates if yer not into doing it yerself. Also - Tasca, Rockauto, etc fer parts cost info. OEM only recommended. Avoid Dorman.
Some useful linkies:
https://www.f150online.com/forums/20...noise-fix.html
https://www.f150online.com/forums/20...iscussion.html
http://www.f150forum.com/f4/final-re...-sound-141266/
And a DIY: https://www.f150online.com/forums/ar...placement.html
Good luck
MGD
Old Jan 4, 2015 | 02:14 PM
MGD thanks for all your help. I have a friend that put me in touch with the parts man at Williamsburg Va. Ford. When I call about the O2 sensors he said he would sell them to me for $66 each. The other Ford dealer what's $97 for up and $66 for down. Think I'll call l him for the cam phasers
Old Jan 4, 2015 | 05:20 PM
MGDfan's Avatar
Hey.
May also want to consider getting the new, revised VCT solenoids as well
http://www.f150forum.com/f4/vct-sole...rdered-229336/
(you'll need new seals too):
SEAL PART #: 3L3Z-6C535-AA
Example: http://www.shopfreedomracing.com/sea...=3L3Z-6C535-AA
http://www.howstuffinmycarworks.com/VCT_Solenoid.html
more info - parts lists, prices, etc - a looong thread - but good readin' ....
http://www.f150forum.com/f4/heres-pi...-marks-140876/
MGD
Old Jan 11, 2015 | 09:02 PM
Kodiac76's Avatar
Tommy I have an 08 F-150 that had the same issue. It was the cam phasers. After all was said and done it ended up costing over $4,000. Thank god for warranties. I bought the truck used about 6 months ago and have been cleaning up after the previous owner since. So far I have dropped about $3,000 in out of pocket expenses into the truck. between warranty deductibles and other misilanious expenses but I can say this it is an awesome truck and am very happy with it.
Old Apr 7, 2015 | 03:41 PM
Up date on my tapping noise. here is what I was told. "Found an injector has failed on bank 2 causing fuel to wash down into the oil, the timing chain now constantly rubbing the timing cover, has causing other damage to the engine. Suggest a remanufactured engine due to cost of a tear down and repair." Sounds like my 5.4 is gone
