Which axle shaft and part number?
Old Jan 12, 2015 | 08:15 PM
gwalys's Avatar
I need help please. I have a 2007 f150 5.4l I am in need of a driver side axle shaft. From what I have researched so far it looks like I have the 9.75 series because I have a 12 bolt cover. When I look for these axles all the pictures show them with 5 lugs. The 8.8 have 6 lugs which is what I have on my truck. Can someone please help explain this to me?
Thank you in advance
Old Jan 12, 2015 | 08:32 PM
Roadie's Avatar
I would say the pictures are incorrect. I'm sure you have a 9.75".
Take a look at the tag on the diff cover. It will tell you the ring gear size and gear ratio.
Old Jan 12, 2015 | 09:40 PM
Call Tasca with your VIN, you will get the right part, and it will be the least expensive OEM option. Looks like Dorman has them - 2 different ones depending on your build date, and they are around $200. The pics of those both show 6 lugs.
Old Jan 13, 2015 | 01:35 PM
SoonerTruck's Avatar
All 04+ F-150's have 6-lug axles regardless of differential size. The only exception is if you have the HD-package which included 7-lug wheels.
Old Jan 13, 2015 | 02:37 PM
Tasca Ford Parts's Avatar
Former Sponsor
Don't even need to call.
PM me the VIN and I can verify what the truck came with and give prices and part numbers for OEM parts.
-Steve
Old Jan 13, 2015 | 05:10 PM
gwalys's Avatar
Thank you everyone for the replies.
One more quick question please. Is it possible for a machine shop to fix a bent axle shaft?
Tasca PM on the way.
George
Old Jan 14, 2015 | 09:41 AM
George
Possible? Sure. Anything can be done with enough time/money. However, it wouldn't be worth it in this case as buying a new one will ensure it meets spec and doesn't have any potential failure points that a reman'd shaft might have. Don't make it complicated, just get the new part.
Old Jan 14, 2015 | 02:25 PM
Former Sponsor
Just responded to your message, thanks.
-Steve
