Westin HDX Grille Guard '05 STX
I didn't install it myself so I'm not exactly sure how the brackets go on. I hit a deer with my truck a few months ago and I had the body shop install it when they fixed the truck. I can get you some better pics of how they go on if that would help.
I also have the westin on my '07 and it was easy to install, I have the tow hooks on mine from the factory so I didn't need to cut but even if yours didn't I don't think you will need to. The brackets run just over the front bumper and bolt to the inside of the frame in front of the radiator, only takes about 30-45 minutes or so.
Update: I could take the plastic inserts out so did not have to cut anything. They just pop off and I don't think I will need to or be able to put them back on after install.
Thanks for the pics. I think I have a good idea of how to get it done. The nut plate will be the challenge, I contacted Westin and customer service is checking with the engineers. Since they furnished heavier hardware there should be a way to use it and I really don't want the old nut plate rattling around in the frame channel so we will see.
Thanks for the pics. Finally got it on, looks great and very stout compared to some I have seen. It was not as easy as the directions. The lower brackets were a breeze but the upper bracket holes did not line up. It said for my year I should use the top and middle holes but no way, I had to use the top and lower and I had to enlarge the lower hole. It was a fraction off but with 1/4" hardened steel a fraction takes some work and a dremel is not meant for that kind of work but was the only thing that would fit. Then the upper support bracket did not mount to the guard the way it showed, very hard/awkward to hold the nut and get it torqued to 55#. The rubber was too long on one side and I had to trim it, a better job for the dremel and that is some tough rubber. If everything had lined up it would have been a few hours project but with the grinding and repainting it was a pain but worth it, especially if I have the occasion to use it. At least I got it done by Christmas, my present from my wife. Merry Christmas and Happy New Year to all.
