How much torque on Sway Bar Links??
Old Jul 31, 2013 | 06:31 PM
CC268's Avatar
Just got my replacement Moogs in and it says like 66 on one of the points and 90 something on the other point...seems like a lot...should I follow the directions or do you guys have a recommendation?
I know some people have worn the Moogs out really fast from over torquing
Old Aug 1, 2013 | 01:22 PM
CC268's Avatar
Anyone?? Putting these on today
Old Aug 1, 2013 | 01:35 PM
We have the stupid 90* ones on our trucks, they are a pain to remove.
The link to bar torque is 98 ft/lbs and the link to lower control arm torque is 66 ft/lbs.
If you find the need to drop the whole sway bar to install, the torque for those brackets is ONLY 35 ft/lbs! Do NOT over tighten those two brackets, I snapped one that I bought since the installer did the same as I and over tightened. Hope that helps
Old Aug 1, 2013 | 10:10 PM
CC268's Avatar
Got em on today they are really nice. I just torqued them snug and then used an impact air wrench to tighten them a tiny bit more. I had a torque wrench but 66 ft lbs and 98 ft lbs was insane!
Old Aug 2, 2013 | 05:41 PM
The work I did today involed 295 and 351 ft/lbs Now that's insane!
Glad everything went well
Old Aug 14, 2014 | 04:55 PM
texasJ's Avatar
I bought some end links for a replacement. I don't have a torque wrench. Trying to decide if I need it. Looks like you couldn't get it all the way to spec. So is it necessary?
Also found the 98/66 spec but also found a 66/18 spec below. Which is right?
