2005 F150 Emergency Flasher Issue
on
If it was the flasher, the one on the driver's front wouldn't be working either.
If the described symptoms are correct (all turn signals work, only LF lamp flashes in HAZ mode), the only thing that could cause that would be the multi-function switch which would require THREE internal points of failure.
I'd suggest double-checking the symptoms to make sure it isn't simpler. If they're correct, replace the MFS.
