I assume the answer is NO, but......
I have a set of 4 wheels that I want to sell, there are old tires on them I just want to take off.
Called a local tire place, they want $17 per wheel to take the tires off and dispose.
Is there a way I can take tires off in my garage without a machine? Could I deflate them totally and then break the bead with something?? I don't care if I destroy the tires either.
You need to break them down. The seal where the tire meets the wheel has an extremely strong bond that you won't be able to break with any normal tools.
Long story short, probably no, sorry.
I've tried to get a tire off a rim to scrap the rim. long story short I took it to the scrapyard cut up with a lil sidewall left on, hoping they'd take it like that (which they did)
some people, particularly ones with old work trucks or whatnot manage to do it, even to change the tires between sets, with screwdrivers, but you might damage the rim. so i wouldn't do it to sell rims. I assume these are nice rims that you can get decent money for
i'd either pay for it, or try to sell as is and let them deal with it. even if you tried to say, take off $40 maybe, vs the $68+tax you'd pay. could work.
I have changed them in the driveway out of necessity. I'm a carpenter so I have a good assortment of pry bars. The hard part is breaking the bead, once that is done it's just like doing a bicycle tire............only bigger. Took about 20 minutes each.
If they are alloy rims then remove them from the back (inside) and use lots of dish soap, it helps a lot.
I take my tires to a friend (he does tire swaps on the side). He charges me $80 for full tire swap INCLUDING balancing.
I've seen him use the equipment and it doesn't take more than 10 minutes to remove all 4 tires from the rims.
1. Apply lubricant to rim.
2. Pry the lip of the tire up on top side
3. Tire machine spins.
4. First-half of the tire is removed.
5. Pry the lip of the bottom side of the tire.
6. Tire machine spins.
7. Tire is removed.
No longer than 2 minutes/wheel.
7. Tire is removed.
7. Tire is removed.
7. Tire is removed.
Only other thing I saw to break them down on YouTube, was a guy that literally took his truck and drove slowly over the tire portion (not the rim). However, I wouldn't recommend this if you care about the wheels even slightly.
