Parking Light Wire
Old Oct 21, 2015 | 06:42 PM
gmcphe's Avatar
Parking Light Wire
Hello Everyone
I am installing a remote starter on a 2008 F150 STX. I need to tap in to the parking light wire. It is impossible for me to tap in at the headlight switch. Is there a more accessible place I can access? Thanks
Old Oct 21, 2015 | 09:33 PM
A thought - if the fuses and relays are installed you should be able to tap into the trailer brake controller connector. Worth a try.
Old Oct 22, 2015 | 07:10 AM
gmcphe's Avatar
Thanks. Where is that connector located?
Old Oct 22, 2015 | 10:44 AM
Under the dash right near the OBD2 connector.
Old Oct 22, 2015 | 11:18 AM
gmcphe's Avatar
Thanks again. I will let you know how I make out.
Old Oct 23, 2015 | 05:21 PM
gmcphe's Avatar
The connector does not have a parking light pin. I was finally found a brown wire in the driver side kick panel that I used. Thanks for your help.
Old Oct 23, 2015 | 07:18 PM
It doesn't have a parking light pin, but it has a running light pin - should be the same thing.
