Spark plug change successful! But :3
Broke 6/8 plugs, lisle worked like a charm. 102,000 miles :3
Now before I changed the plugs, I had a wot bog through 1-2 that caused the truck to stall and pop, but now that the plugs are done I still have it.. So what else could it be? I modified the intake housing from sucking in to much air. I do have a k&n drop in filter with gotts mod, but it's not over oiled and it's clean. Might switch it to a paper filter and re clean MAS, fuel filter was changed not to long ago. I cleaned throttle body about 6,000 miles ago. Could coil packs cause this? Their is no cel either.. :P
I'd say possible coil packs had to replace one when I changed my plugs. Also replaced the rubber boots on the rest of the coil packs for good measure during the tune up on my truck.
