squealing noise from intake
Old Nov 27, 2013 | 11:10 PM
worm5932's Avatar
On my 08 5.4 today there was a squealing noise coming from the drivers side injector, upper intake area. It didn't sound like it was under the valve cover. It was cold, 20° and I started it and drove it across the parking lot and it did it while idling. I gave it a little throttle and it went away but started again when it settled back to idle then stopped after a couple minutes.
Thoughts
Old Nov 28, 2013 | 08:14 AM
MGDfan's Avatar
Thoughts & Thanks!
^^^ FIFY.
Nothing in the intake will 'squeal'.
Possible culprits = idlers, tensioner, alt / PS bearings, etc.
Also - belt itself, spooge on the pulley surfaces ...
Remove serpentine belt temporarily - does squeal disappear?
If replacing belt use a Gatorback.
Old Nov 28, 2013 | 09:07 AM
worm5932's Avatar
I was able to pop the hood and look at it while it was happening. im confident in the area it was coming from. maybe squeal is a bad description, maybe more if a hiss so high pitched it squeals. my first thought was fuel passing through something.
thanks!
Old Nov 28, 2013 | 09:13 AM
MGDfan's Avatar
thanks!
Okay.
Sound is a funny thing - so much ambient cacophony under there. I can honestly say I've never heard fuel flowing through the injector rails.
You can, and should, rule out rotating components by yanking the belt - only takes a couple minutes.
If it still makes the noise, we can try to proceed from there. (vac hose collapse / connection / leak, PS fluid gurgle, etc).
Good luck! And yer welcome, lol!
MGD
Old Nov 28, 2013 | 12:09 PM
You sure it's not the alternator whine? Usually happens at start-up then calms down and comes back at certain rpms.
Darren's old video from his '04:
Old Nov 29, 2013 | 12:39 PM
Originally Posted by MGDfan
^^^ FIFY.
true....but air moving through the intake passing over a CMCV that has come out of adjustment or stuck with debris....a long shot of a guess though....
Old Nov 29, 2013 | 03:36 PM
MGDfan's Avatar
Point.
I was going from the initially reported description of the sound.
Air leak in intake tract?
MGD
Old Feb 3, 2014 | 09:32 PM
Hanslives's Avatar
Thanks guys. I just bought an 2006 FX4 and had a whistling noise driving me crazy. I swapped the alternator and that fixed it. I never would have guessed. Thanks for saving me a ton of money time and frustration.
