Radio door lock problem
This is an 07 FX2 stock supercrew with the exception of an Edge Programer. Normally when the ignition is turned off the radio stays on for 10 minutes or untill the door is opened.
Now when the ignition is turned off the radio stays on, when drivers door is opened the radio stays on, close the door and lock with the fob radio stays on??? Radio will turn off if P/side door is opened.
Also the drivers door power lock switch is not working, passenger side lock switch is fine. In the past I had noticed that when the truck was put into park the d/s and p/s door locks would unlock automaticlly but not the rear doors.
