Just finished lift kit install...
I understand that you changed the bolts around in that last picture after it was took ...
... but just looking at the picture, ... see you used "camber" bolts for attaching the new cross member below the oem cross member first time.
Did they come with the kit ..... and were there not some plates that fit behind them with "walls" that locate on those smaller holes so they can be used to adjust camber if used on the actual LCA pivots?
Just curious.
Nice Work!
I had to swap these at the very end. Not hard but annoying so if you're doing this yourself, the fat washers go on bottom
Just curious.
Nice Work!
