Power points not working
Old Jul 15, 2017 | 01:00 PM
jfoliver's Avatar
The dash and rear seat power points have stopped working. I have checked both fuses in the passenger side fuse panel and both are fine. Is there another place to check?
TIA
2004 f150 super cab lariat 4WD 8cyl
Old Jul 23, 2017 | 11:50 PM
Bluegrass's Avatar
Dash fuse is #39, rear is #37.
Check with a voltmeter to see if the fuse holder positions have power and if fuses is passing it..
Be sure you got the right fuse locations.
Look in owner manual starting on page 199.
Good luck.
Old Sep 18, 2017 | 04:37 PM
jfoliver's Avatar
Thanks for your reply
The fuse holders are not receiving any power
I am lost at where to check next
Old Sep 19, 2017 | 12:59 AM
Bluegrass's Avatar
If your sure there is no power to these two fuses on the FEED side, check others in the same line up.
If they have power, there is a problem on the underside of the fuse panel with the factory connections on the two that do not have power.
If more than these two have no power then there is a main feed issue to the bar on the back side for that row of fuses.
You will have to check the back side carefully and safely for a connection problem.
Keep using a voltmeter to find out where the power is found and lost.
Some times the wire crimp is no good.
Good luck.
Old Sep 26, 2017 | 08:44 AM
schapman1961's Avatar
I also have problems with powerpoints.
Maybe someone here can help. My powerpoints seem to have power but when I plug an accessory in, they quit working. I checked fuses and they are ok, Seems to be a problem in the dashboard and the one for the rear seat which is located on the back of the center console.
This problem just started a week ago.
