Dash Airbag Light Wont Go Out
Vehicle:
2006 F150 XLT 4X4 Supercrew Cap
I did the repair that was described in a different thread (https://www.f150online.com/forums/20...any-ideas.html). Essentially the repair was to re-solder connections in a specific area on the front of the board near the needles. This was to solve an issue with my brake light staying on. However when i put the cluster back in the truck the airbag indicator LED illuminates. I used a multimeter and measured ~998 Ohms across the LED (the other LED's have little to no resistance). Does anyone have any ideas what might be wrong? Does anyone have a cluster wiring diamgram for the airbag light in the cluster? There are no trouble codes stored in the PCM (nore has there ever been). This is an issue only as a result of re-soldering on the instrument cluster board. Any thoughts on this subject would be appreciated.
