Heater A/C issue
Heater A/C issue
Hey everyone,
I have used this forum to help solve countless problems over the years with my 2004 f150 so thank you to all the contributors. I have a weird issue now that is perplexing me. I have a 2004 f150 5.4. When the A/C or heat runs for 45 mins or more the flow of air seriously decreases, at times just to a trickle. You can hear the fan working the same but just about no air coming out. When I turn the temperature down when it is heating or turn it up when it is on A/C, within a 5 -8 minutes the flow is back at full. It doesn't seem to matter what vent setting it is on either.
Any suggestions?
Any suggestions?
on
Turn off the A/C then and see if the problem doesn't occur.
Generally, evaporator freeze-up is going to be caused either by a mechanical failure with the clutch (stuck in the engaged position) or by it's control system causing it to remain engaged when it shouldn't, often by a cycling switch that is stuck closed.
Good luck.
Good luck.
