Windows Inop With Driver Door Open
Old Jul 6, 2012 | 08:23 PM
Gordon M.'s Avatar
Windows all inop when Driver's door open but all work with door closed,I am assuming there must be a wire issue in the driver's door has anyone else had this issue?
Old Jul 7, 2012 | 05:12 AM
code58's Avatar
Pull the rubber accordion sleeve from the door to the cowl post back and you'll probably find the ground wire (probably black and fairly large) is broken. There has been an issue with that ground wire for a while because the wire is to stiff and ends up breaking from the flexing of opening and closing the door. If you find that's the problem, just use a "loop" of the same size wire to do the repair rather than trying to re-connect the broken ends. That will take the stress off of it and keep it from breaking again. A loop of about 4 or 5 in. in diameter should do fine. The wire likely touches (broken ends) with the door closed but doesn't make good enough contact with it open.
Old Jul 7, 2012 | 06:49 AM
Gordon M.'s Avatar
Thank You Sir! Exactly the tip I was looking for it will be tomorrow before I can look at it & will post the results.
Old Jul 7, 2012 | 08:14 PM
Gordon M.'s Avatar
Got it fixed in My case it was the Blue with Black Tracer (Power Wire for Windows it was broken fixed it with the wire like you said, Thanks for the Tip!
