ABS Sensor Question
ABS Sensor Question
I am getting an ABS code for rear wheel speed sensor. It is a circuit fault on rear sensor. How can I test the sensor to see if it is good or bad? Would old fluid in differential make it throw the code? I can post the code, but I will have to go out and read it again.
Got an ABS code on my truck about a month ago. Light came on once, and never again. Scanned it, found the code was the rear sensor. Cleared it, and not a thing since.
Talked to the mechanics at work, and they said it's possible that the sensor could just get some dirt or debris on it and it will throw the code because the dirt or debris is causing it to not read properly as the diff turns.
If it comes back again, then I'll worry. But, until then, I'm not the slightest bit worried.
Also, something one of the guys at work told me. If you do a rear sensor like our trucks have, it's probably a good idea to flush and re-fill the diff because pull the sensor can allow dirt and debris to get into the diff.
But did you clean it? I didn't see that you did.
