Which level to go with 2" or 2.5"???
I have a 08' F150 lariat supercrew. Everything is stock on it right now but I want to level it out. I have searched on here and found that the 2" level is fir the 2008. This is my question. I tow a 29' travel trailer and want to add a 1.5 AAL to the rear end will the 2" AS level still work or am going to have to go with the 2.5"AS level to get sitting level with no load on it?
Go measure the height differences between the front wheel wells and read wheel wells. Determine the difference and plan accordingly with the 1.5" AAL
Best way to get the accurate leveling kit.
The 2.5" will probably get you closest to level with the 1.5" AAL, but the best way is to measure it like Barrett said. You might also want to look into air bags for the rear with towing a trailer that large.
ok, thanks fellas. Im going to pull into the shop tonight after work and get a measurement. Will someone be able to tell what I need just by measurements and if I need the AAL or airbags?
going with the 2.5 AS and then adding the 1.5" AAL form autospring would it sit level or have a rake again?
My truck is an 05 and I have a 2.5 level and a 1.5 AAL. I still have some rake unloaded. I pulled 31 ft travel trailer and even without the load level hitch it would sit dead even. I don't mind a little rake so it's cool with me. If you don't like the rake I would suggesst air bags in the rear so you can adjust as needed. Pictures in my albums of truck and truck with trailers.
Ok so I took some measurements of all the wheel wells,
FRONT LEFT AND RIGHT 37"
REAR LEFT AND RIGHT 38.5"
MIRRORS 50"
Can i still get away with the 2.5" AS level and the 1.5 AAL??? Im ok with a little bit of rake 3/4 is acceptable.
Thanks in advance.
MIRRORS 50"
Thanks in advance.
If you mean the front higher than the back I don't think you will have any worries.
