Stuck on 4X4 low
Stuck on 4X4 low
Hello fellows, first post here but not new to the site. I have been looking on this awesome forum for a while and have gotten great information.
I had an issue with my 2004 FX4 SCREW with the 4X4. I had noticed when it rained mostly and I tried to switch to 4X4 the light will come on for just a moment then out. After that I could turn the switch and no lights would come on. Eventually, some other day it would work again.
By reading this site I decided to change the solenoid yesterday. I replaced it with the new model, turn on the 4X4, not raining, and it did the same. Only that after I turned off the truck and back on, with the 4X4 switch off, it turned on on 4X4 low and just can't get it out of there.
I read that the issues can be on the TC motor. If I check for curent on those cables do they have constant power or is it just momentary when you turn the switch?
Also, somebody else reported a corroted cable on the distribution box under the hood. I imagine this is the one sending power to the tc motor. Can somebody tell me where that box is and how to identify that cable?
Thanks in advance!
HM.
Thanks in advance!
HM.
Update : problem fixed. Thanks to all the valuable information in this forum I was able to fix the problem. For anybody having problems with 4x4 engaging, light turning on and immediately off; take off the two relays under the hood and clean the contacts, wd40 and scrape them with a flat screw driver. It now goes in and out immediately....I am glad I did not change the TC switch.....
Little Tip: Apply corrosion resistant grease or Dielectric grease to the terminals next time to prevent the corrosion from starting.
