I have one doubts i need aid
Old Jul 7, 2010 | 11:43 PM
EXTASIS's Avatar
GREETINGS TRUCK MANIAC…
MY DOUBT IS, TO THE BOX OF TRANSMISSION, CHANGES THE OIL TO HIM?
IF ONE CHANGES TO HIM,
EACH WHICHEVER MILES ARE THE RECOMMENDABLE THING?(THAT OIL TO USE?)
EQUAL FOR THE TRANSFER… WHICHEVER MILES SELE CHANGES THE OIL?(THAT OIL TO USE?)
EXCUSES USE A SPANISH TRANSLATOR - ENGLISH
THANKS THANKS
Old Jul 8, 2010 | 12:17 AM
ELVATO's Avatar
You are asking, how to change the transmission oil, at what interval/mileage, and what type of oil to use?
The same question for the transfer case?
Estas preguntando come se cambia el aceite de la transmisión/caja de cambios (no se como se diga en tu país), a que kilometraje/o cada cuando se debe de cambiar, y el tipo de aceite que se debe de usar?
Y la misma pregunta para la "transfer case" (no se como se dice, caja de baja tracción?)
Old Jul 8, 2010 | 08:19 AM
bambo2888's Avatar
lol, SWEET!
change tranny fluid every 30-50k miles with tranny fluid.
Old Jul 8, 2010 | 09:32 AM
ELVATO's Avatar
Mercon V/5 to be exact. A shop may have to do it using a flushing machine.
Old Jul 8, 2010 | 09:54 AM
greencrew's Avatar
THANKS THANKS
Many of my team mates speak Portuguese and use translators. Let me see if I can interpret this.
I have a question.
Greetings fellow truck enthusiasts.
My questions is, do you change your transmission fluid? If you do, what mileage do you recommend changing it at, and what fluid do you recommend using?
Same questions for the transfer case, do you change it, what mileage, and what oil do you use?
I apologize if my question is not clear, I typed it in Spanish and translated it to English with an online translator.
Old Jul 8, 2010 | 10:14 AM
coiledup's Avatar
Your owners manual in the glove box should tell you what the manufacturer recommends. If not take it to your dealer and ask what they recommend.
Old Jul 8, 2010 | 12:14 PM
EXTASIS's Avatar
GREETING TRUCK MANIAC….
INDEED MY QUESTION IS...
MY TRUCK HAS 80.467 KLM / 50.000 MILES
CHANGES THE OIL OF THE TRANSMISSION ?(THAT OIL TO USE?)
TO THE BOX OF TRANFERENCIA THE OIL CHANGES TO HIM ?(THAT OIL TO USE?)
THAT AMOUNT OF MILES?
AQUI PREGUNTO EN ESPAÑOL
SE DEBE CAMBIAR EL ACEITE DE LA TRANSMISION ??(CAJA DE VELOCIDADES) QUE ACEITE SE USA?
IGUAL AL TRANSFER SE LE CAMBIA AL ACEITE?? (QUE ACEITE SE DEBE USAR EN EL TRANSFER)
Y POR ULTIMO A CUANTAS MILLAS SE RECOMIENDA EL CAMBIO DE ACEITE DE ESTAS PARTES....
THANKS FOR YOU ATTENTION….
GRACIAS POR SU ATENCION....
Old Jul 9, 2010 | 10:54 AM
NCSU_05_FX4's Avatar
I saw Venezuela from the coast of Trinidad a few weeks ago... lots of oil platforms in the ocean over there.
Do you have an owner's manual for your truck?
- NCSU
Old Jul 9, 2010 | 01:28 PM
If you have 50,000 miles and the transmission fluid has never been changed, I would recommend that you do change it, use "Mercon V" ATF.
At 100,000 miles, do it again. At that time, change the transfer case fluid and the differential fluids. The transfer case uses the same Mercon V ATF, the rear differential uses 75W-140 synthetic gear oil, and the front differential uses 80W-90 or 75W-90 gear oil. If your rear is limited slip, you also need 4 ounces of friction modifier.
Old Jul 9, 2010 | 01:48 PM
EXTASIS's Avatar
FRIEND NCSU 05 FX4 , I HAVE IF IT BUT IN THE MANUAL,
HE DOES NOT INDICATE CHANGE INTERVALS
ONLY INDICATES AMOUNTS…
Old Jul 9, 2010 | 01:52 PM
EXTASIS's Avatar
FRIEND, GLC THANK YOU VERY MUCH
YOU ARE SOLVED THE PROBLEM
I AM TO YOUR ORDER
Old Jul 12, 2010 | 02:22 AM
EXTASIS's Avatar
THEY CAN INFORM TO ME
INTERVAL RECOMMENDED FOR OIL CHANGE IN THE TRANSMISSION?
50.000 MILES
20.000 MILES
100.000 MILES?
THANKS TO ALL TO TAKE CARE OF TO ME
Old Jul 12, 2010 | 02:48 AM
ELVATO's Avatar
50000 miles, then again at 100,000 miles.
Primero a los 80,467 kilómetros, y después a los 160,934 kilómetros.
Old Jul 12, 2010 | 02:49 AM
expedition4x4's Avatar
Old Jul 12, 2010 | 12:59 PM
EXTASIS's Avatar
THEN REGULARLY EACH 50.000 MILES ??
I MUST DO MY FIRST CHANGE
EXACTLY I HAVE 51263. mi.
SOME HAS I NUMBER OF PART OF THE OIL FILTER OF TRANSMISSION
F150 FX4 YEAR 2006 ?
THANKS TO ALL
