Airbag light is on. Should I pull a fuse?
My airbag light started blinking a few days ago and my horn is also not working. I setup an appointment for Thursday to have the airbag harness/clock spring recall done (should have done it a while ago obviously). From what I have read this should solve the problem.
In the meantime, is there a way to disable the airbag so I don't risk it going off on its own? The wires must be chafed in order to set off the light so I believe I am at risk for an unintended airbag deployement. Is there a fuse I can pull or some other simple way to make sure this doesn't happen?
on
Is it a steady flash ..... or is there a code being flashed?
Watch it close, it's likely trying to tell you what's wrong.
http://www.answers.com/Q/Is_there_a_...ht_error_codes
Here's some more on SRS and codes and 2004 F150s:
https://www.f150online.com/forums/20...ode-4-2-a.html
